str rear fog lights
Old 12-07-2011, 06:42 AM
cue244's Avatar
I work for a fire department and I am thinking of putting a Flasher on them to give me some rear warning without cutting holes in tail lights for strobes.
Old 12-07-2011, 07:18 AM
Stillwaters's Avatar
Originally Posted by plums
Good for tailgaters on freeways that are annoying you. They tend to back off or pass once you turn them on. But, try turning them on when no one is behind you so that they do not believe the action is specifically designed to annoy them.
Tailgaters...
I have been rear ended twice in the last two years (luckily not in my Jaguar). In both cases, although traffic in front of me had stopped suddenly, I still had enough time to look in my rear view mirror, see the idiot tailgater six inches behind my rear bumper, and start repeatedly pumping my brakes to get his attention. Of course in both cases, "dumb a--" failed to look and BANG! Time to call the State Police.
BTW, in one of the cases, "dumb a--" told the trooper he had "sneezed" and that is why he did not stop in time....
"Dumb a--"
Old 01-22-2016, 11:35 AM
Mad_Russian's Avatar
I am thinking about replacing factory bulbs in rear fog lamps with LEDs and running them all the time
Old 01-22-2016, 11:58 AM
Received 2,263 Likes on 1,845 Posts
Great way to fail a safety inspection or get pulled over by the cops!
Old 01-22-2016, 12:17 PM
JagV8's Avatar
Received 4,534 Likes on 3,943 Posts
Both, over here.
Old 01-22-2016, 01:14 PM
I should have clarified - I am in Ohio, US. Around here very few cars have rear facing red fog lamps (mostly older European imports like Jaguar, Land Rovers, etc.) It's perfectly legal to drive with them on whenever, and no one really cares. Except it looks kind of interesting. But it's good to know that you can't drive with them in Canada.
Old 01-22-2016, 01:31 PM
JagV8's Avatar
You probably can in fog (or falling snow or maybe some other times, if like here) - basically any time conditions make it hard for your car to be seen if you just have normal rear lights on.
Mad_Russian (01-22-2016)
  #28
Old 01-22-2016, 01:35 PM
Thanks, JagV8! I just looked up Ohio Revised Code on fog lights, and we don't even have a mention of anything to the rear. So I agree - bad weather, turn them on.
Lawriter - OAC - 4501-15-06 Spot lights and auxiliary driving lights.
Old 01-22-2016, 02:04 PM
Bright red lights at the rear of a car that look like brake lights must actually be brake lights and operate as such. If they don't go on and off with the brake pedal, and instead are on at all times does not comply with road safety regulations- in any state of the union.
  #30
Old 01-22-2016, 02:26 PM
JagV8's Avatar
Interesting. Virtually contrary to here, then, where the intention is that in bad enough conditions fogs be used to render a vehicle visible (rather than hard to see until too late).
  #31
Old 01-22-2016, 04:48 PM
Let me restate- they are not illegal to have on a vehicle here.
There are no regulations preventing such. There's also no regulation to mandate that they be present. Since there are no regulations mandating their presence there are no regulations saying that you must or should use them under certain circumstances and not under other circumstances.
On the other hand, there are regulations that govern the number, type, placement and brightness level of park and brake lights. A vehicle driving around at night in clear weather with what appears to be brake lights that are on at all times contravenes the law governing vehicle lighting and will attract unwanted attention from the wrong people.
Ticket or not, we've all driven behind the a**hole that leaves his rear fogs on all the time, just like the a**hole that won't dim his high beams.
Don't be that a**hole.
joycesjag (01-22-2016)
  #32
Old 01-22-2016, 05:11 PM
JagV8's Avatar
Other than that here they're required to be fitted (I think), that's quite similar. Using them in clear weather here is also asking for trouble (likely to be rather minor).
99xk8guy
06-05-2023 06:28 AM
mbergen
10-23-2019 10:26 PM
rachelstr
09-03-2015 12:59 PM
King Charles
09-03-2015 12:40 AM
OkieTim
09-02-2015 12:48 PM
Quick Reply: str rear fog lights
