STR Rearend / rear end leak, gasket and oil?
Do you have anything dripping??
My 2005 STR had some oil and dirt on the rear end. I changed the fluid and was careful to measure what came out and what I put in. They matched as close as I could tell. That was 30K miles ago and it's still a bit oily and dirty. I think it's just a small seep or weep. There is no drain plug so I siphoned the old smelly stuff out and put new smelly stuff back in.
Wanted to follow up on this old post.
Turns out there is a vent on the passenger side on top of the rear diff. It has a short bit of rubber hose that just slides onto the steel section.
It seems that with age and miles you will get some fluid up and out of this tube. I just started to get a few drips of rear end oil on the ground and I think the rubber section has rotted off.
It's hard to get at so I am not sure yet but I have checked the fluid level and cleaned the rear diff as well as I could. I have ordered a new vent tube since they are still available and pretty cheap.
XR81873 about $10 from Terry's Jags. We will see if that is the problem.
innzane
09-02-2015 10:08 AM
