STR refresh plan
STR refresh plan
Hello All,
In the few days I have owned this 03 STR, I have found the biggest asset has been the forum. The gift of experience by many has moved this along quickly and help keep the costs under control. With this help this will be a driver for me likley replaceing a SUV and my Lotus.
A maintained STR or S that has not been abused or badly molested can be a relatively trouble free and great fun..these are used cars but having owned several british cars, Ford made huge strides in improveing the contemporary Jags. Brakes parts and service can be had from conventional sources ( NAPA, Advanced etc) and the local Firestone or small shop can performe the job for a lot less than the $1100 the dealer needed for just the front.
This is a great car and worth the time to get it up to speed..
- Yesterday, fresh front rubber at Firestone ( Primwells for $96.00 + mounting, balance and taxes) $10.00 to rebalance the very new rear Firehawks and check the new acquired alloy wheel, these things,can crack when first put into service. Oil change and some small items.
- Tomorrow the brakes ( rotors and pads will be replaced by a local shop with Wagner OEM that priced at $55.00 for rears, $80.00 for fronts and about $150 for all pads, labor will be $160.00. If the brake fluid looks old, drain and replace
- the same shop will replace the serpintine belt ( $22.00 for belt and $15.00 for labor)
- if there is time a fresh thermostat and spark plugs
- Next the current Jaguar brand battery is 4 years old so a fresh battery and ground cable..any suggestions for a practical replacemnt? ( $400 for an Optima is not likley) looking for at least 700 CCA
- The transmission "lurch"..this may be inherient and no real solution..local Jag expert ( former dealer tech) will reflash the tranny ECU and we hope that smooths out the down shift in to first. He quotes $750 to change the fluid and filter.I read the proceedure and it is a pain to do along with what ZF gets fror the fluid. $200 for the pan/filter!!!
- I need a replacement key and a reprogram/replace the key fob transmitter..probably be forced to see the dealer...frankly they are a snoobish bunch. I arrived in my Lotus and half the sales staff comes out to ask about when I can make an appointment to drive a new XK, but mention some issue with a 03 S type and they act as if I was a poor country cousin.
- a chipped windshield to be addressed by a local repair
- a couple of parking lot dings..we will ask the Dent X guy if he can improve these w/o a trip to the paint shop.
- when is it changed and where is the fuel filter?
- Next week, I hope to replace the "lowered" springs for stock to improve the ride as an accommodation to the wife.
Let me know what springs were in there and what you plan on doing with them once they are out.
Sounds like a decent plan. Are you sure the pads are that cheap for the brembo calipers? That's a great deal if they are.
I put the biggest Optima Yellow top I could find in my car. Granted I have a ton of aftermarket stereo crap. You can get it for about $260 online. Reg batt (Interstate, and I think Die Hard from sears (rebranded interstate), both made by Johnson Controls are around $140-160.
Thanks,
George
Thanks,
George
PhilT (04-15-2011)
You can order the ZF kit here for about $250 shipped. Oil change kit for 6HP26/28/32
I paid my local shop to change it, should be a few hundred less if you can do it this way. My car has all the latest updates and the only lurch I have is a 1-2 lurch under certain acceleration conditions. Otherwise it's smooth as butter. As this car is already 8 years old and paid off I can live with things that I wouldn't on a newer car under warranty.
PhilT (04-15-2011)
SoCalJagS
09-27-2015 09:20 AM
