STR sound clip
I got a 2003 STR with almost 160 000 kms. the engine has been starting to make a ticking/clicking noise from the driver side im pretty sure & a hissing sound like a got a vacuum leak but cant see it anywhere. heres a link to a sound clip i recorded http://rapidshare.com/files/410912280/VID00035.MP4 i tried to post it on youtube but the sound came out even worst then what it is. i hope this link works out fine & someone will have a idea on what could be making the noise. thanks for any help
By the way is there a way you can take a sound clip while revving the engine??
![Icon Emm](https://www.jaguarforums.com/forum/images/smilies/icon_emm.gif)
It sounds like the sound emitted when oil is not pumping up the lifters on engines with hydraulically actuated lifters...clatter...clatter.... = valve lash. The STR has over the head cams though (no hydraulic lifters). The cam followers are known to break on some engines emitting a similar sound. Or a/the cam shaft (s) are worn? The car has 160 kilometers, huh? Perhaps perform a compression test to rule out worn camshaft(s), and inspect cam followers, etc.
I just looked at the JTIS for a 2003 V8 and it shows a valve adjusting shim so apparently there's no hydraulic valve lash adjustment. I am disappointed but then The first Lexus V8s didn't have any either and they did very well.
But what did confuse me was it shows variable valve timing yet I've read everywhere that this didn't arrive until the 2006 MY??????
Bob S.
Bob S.
I understand they only fitted VVT to the STR to get past tight emissions laws (probably from CARB). Could be a myth, though.
It looks to have needed a newer type of PCM judging by the elec diagrams, connector pinouts etc (and it appears it IS a newer type of Denso PCM). This must make software (calibration) maintenance a nightmare.
Arrgggghhhhh....that vaccum sound is over powering the clicking sound behind it, I can't tell if thats the same sound mine makes only when I rev the engine(the clicking) or not, but anyhow I really hope some one on this forum can help solve your issue/s.
I have a JTIS dated up to 2003.
The V8 engine diagram in that JTIS clearly shows VVT.
So what I understood from your initial answer is that they left VVT off of the STR rom 2003-2005 but that it WAS on the NA engines from 2003-2005.
My question is. If that's the case why would they have done that?
Especially for such a small number of engines.
I don't even understand why the wouldn't have VVT on any engine. I first had on one of my cars in 1990 over twenty years ago.
Does it not provide any significant performance improvement with a supercharged engine? I understand about the emissions angle. That very well could be the case. California decides a lot things for the entire planet.
Bob S.
My guess is that there was some technical reason why they couldn't have VVT on the initial STR. If I had to guess I'd say the PCM could not handle it, whether for number of I/O pins or the speed or the memory available but that is just a guess. When they added VVT to the STR they also went to a newer design of PCM, but that could just be coincidence.
I understand it does not provide any performance gain worth talking about (if any at all) on the STR. I don't know enough about SC cars to say whether that's to be expected or not.
It's possible (but I don't know) that with VVT more power could be available but is not enabled. If (that's if LOL) that's the case, my further guess would be to do with emissions.
I'm out of my depth, sorry.
I listened to the audio/video file and mine sounds exactly like yours, maybe louder and it has only 42k now (2005). The is my first STR so do they all sound like this? I would think that the Jaguar dealer that just changed my oil would have said something???
Should I be worried?
Thanks a lot for the help & sorry for taking so long to get back on here. Heres another sound clip that u can hear the clicking better http://rapidshare.com/files/411416321/VID00037.MP4.html the sound is definitely not normal..mine has only been getting worse.
I finally took my 2005 STR in and oddly enough I never thoguht about turning off the AC. We heard the clicking, and it's been getting worse. We turned off the AC and it went away. The dealership's mechanic said it's the A/C compressor. He even said that the A/C was still working fine, putting out the right temp, etc. The good thing is mine is still under warranty and tomorrow they're going to replace it! So if that is it, I'll let you know. But the sound clip is exactly what I'm hearing.
