Stripped Oil Drain Plug
Hey guys,
After 140k miles, my V6 S-Type 3.0 has a stripped drain plug. Anyone know where I can get the cheapest replacement plug?
Autozone has one for $4.99, but I can wait, if online places have them for less. My oil still has 2k miles to go
Also, any tips on how to get the drain plug out?
Received 13,033 Likes
Hey guys,
Hi gtmaster303,
Is it your assumption that it is the drain plug itself that is stripped, or the threads in oil pan? The drain plugs are usually steel, so it's usually the threads in the aluminum sump that strip.
The self-tapping oversized drain plugs from AutoZone and others do work, and given the likely cost of postage, it's unlikely you can save much over their price. Just choose the size and thread carefully, and take extra care not to overtighten the new drain plug. When I had to do this on one of our cars I cleaned the sump opening and the drain plug with acetone and used a little RTV sealant to help promote a good seal with the drain plug just gently snugged.
If I understand your post, you're not currently leaking oil around the drain plug even though the threads are stripped. I don't know if I would personally trust a stripped drain hole; if it decides to begin leaking rapidly your engine could be damaged before you realize your oil is too low.
If the drain plug turns counter-/anti-clockwise but won't thread out, you may be able to grab it with some Vise-grips/Mole-grips and pull while turning the plug to get it to grab what remains of the threads.
Please keep us informed!
Cheers,
Don
Hi gtmaster303,
Cheers,
Don
Cheers,
Don
Don B (09-13-2014)
Don B (09-13-2014)
Don B (09-13-2014)
Don B (09-13-2014)
Aha! Now I understand. If plums suggestions of using a six-point socket or Vise Grips don't prove successful, I've had success filing all six flats down a little so the next smaller six-point socket will fit.
And to reinforce plums' mention of a six-point socket, that's the only kind you should ever use on a drain plug. 12-point sockets are notorious for rounding hex heads, especially on screws like drain plugs that are loosened and refastened many times over the life of a vehicle.
Cheers,
Don
Don B (09-13-2014)
Cheers,
Don
Cheers,
Don
aholbro1
08-05-2021 05:02 AM
