Stuck in park...neutral switch?
Hi everyone, new member here so thanks for this great site!! I have a 2003 S type R with 78k miles on it. Today i parked on a perfectly flat hill and turned the car off. I returned a few minutes later, car started just fine however i cant get it out of park. I checked the fusses and brake lights and everything seemed fine. in searching the web it sounds like maybe the neutral safety switch might be the problem? if so i cant really seem to find anything to show me where the switch is or what part # i should buy to replace it? any help is appreciated!! Thank you
great advice! i got everything apart and it looks like its the Gearshift interlock solenoid thats not working. i can force it open to allow the gears to shift but then of course i cant get the keys out of the ignition. So i guess ill replace the solenoid, any ideas on what/where to find the replacement? sorry I'm not that good with electrical. Thanks again
Be very careful about forcing the shifter. You will break a plastic part that is expensive to replace. Also be aware that the problem is wide spread and there are aftermarket steel parts to replace the plastic that breaks.
Look here for various shifter parts you might need.
http://www.motorcarsltd.com/_search....ge=1&q=shifter
yes thank you. i was very careful and dint force anything so the clip is still in tact/ I have tested the solenoid and it is working fine. so know I'm kinda back to square one..I know its not the solenoid, i know its no the bolts holding the cable tot he trany, i know its not the clip in the shifter module...I have the entire shifter module apart so i can examine and test it but I'm at a loss.........
Btw, if you can put power to the solenoid and it works, it's not the solenoid that's bad. Most likely the brake switch, not tripping the solenoid on it's own. My old X-Type was wired to the cigarette lighter (but I pulled the ash tray and wired it so it wasn't visible). This was cause like you, I needed to drive the car, and it happened over a weekend. Funny thing is it stayed (and worked) this way for almost 4 years till the car was totaled.
George
I agree, but it would be FAR more helpful if they reported back with results and/or the fix. If two or three people had the exact same issue and it was resolved in the same way that would be immensely helpful, far more so than you can try this or that. You don't have to be a frequent poster, but if you're going to solicit help it would be a courtesy to report back with a solution or update.
