Sulfur smell and rough idle
I noticed something yesterday that I didn't notice before. I started the car seeing if I could find an vacuum leak. After a minute or so I started smelling gas. I shut her off. Now I just had the oil changed and a new fuel filter installed. I wonder if it was installed incorrectly or not secured correctly? Could this be the culprit?
Did you figure out what was wrong with it? I'm having similar problems with mine. started a couple o days back. My codes were P0300, P0301, P0303, P0305, P0335, P1313 and P1111. The mechanic i took it to, checked the crankshaft position sensor and found nothing wrong with it. But i changed all the spark plugs anyway. Still have the same set of codes and restricted performance.
![Confused](https://www.jaguarforums.com/forum/images/smilies/confused.gif)
Jumpin' Jag Flash (07-26-2013)
Did you figure out what was wrong with it? I'm having similar problems with mine. started a couple o days back. My codes were P0300, P0301, P0303, P0305, P0335, P1313 and P1111. The mechanic i took it to, checked the crankshaft position sensor and found nothing wrong with it. But i changed all the spark plugs anyway. Still have the same set of codes and restricted performance. ![Confused](https://www.jaguarforums.com/forum/images/smilies/confused.gif)
Its a 2003 S Type 4.2 V8. 112k miles. I had these details in my signature setting, but dont know why its not showing up in my post.
I drove the car maybe 5 miles to and from the mechanic after the restricted performance warning showed up. Is there a way i can figure out if its a problem with my cats before trying to replace them? Or anything else I can ask the next guy to check or change?
Thanks for the response guys,
- Atul
- Atul
