Sunroof drain question.
My left front drain is not draining.. I used a 6ft piece of 120lb stiff fishing leader line down from the top and it goes all the way down behind the front wheel 5-6in from the end but I can't get the stoppage out... Will that section be exposed if I remove the wheel well cover.. I can change my fuel filter while I'm in there too.. Thanks
Thanks but I fear blowing the line off the fitting inside and then have to remove my headliner to repair that.. I've researched this and that has happened.. If nobody knows I'm going to open the back of that wheel well and see if it's there.. It's where the water runs out on the other side..
mikebaker3
50
07-20-2019 11:42 AM
