Sunroof is stuck open.. Help Asap!!
![Exclamation](https://www.jaguarforums.com/forum/images/icons/icon4.gif)
I've been trying to get my sunroof close for the past hour. I had open my car windows and my sunroof is now stuck fully open and wont close at all. Is there a Reset switch or a way to Manually close the sunroof?? Help asap!! Thanks
02' Jaguar S-type 4.0
I'm trying to find a fuse diagram for my car to see if the Sunroof fuse went bad. Do you know where to find a 02' Fuse Box Diagram?? Thanks for reply
You can close it manually but you have to remove the moon roof console and then the motor. The motor drives the moon roof with a square drive. You will need to find a matching square wrench to crank it closed.
But if it had been working it most likely will come back. Things can get hot and then stop when overheated.
Remember that if you move the moon roof without using the switch it will throw the moon roof out of sync and you will need to resync it. The procedure is in the service manual.
Do your windows work?
One other thing. Can you hear the motor running when you press the switch? You could have broken a cable or had something go off track but I have never heard of it on the S Type?
bfsgross (11-08-2011)
Received 6,330 Likes
and you can find the wiring schematics here Jaguar electrical reference
Good luck.
