Supercharger belt Change
Michael Star - I ran into the same issue - you can loosen the tensioner bolt (13MM bolt size) - use a 1/2 inch drive 6 point socket not a 3/8 inch drive or 12 point socket - you'll risk stripping the points off the bolt - that bolt is on tight! Once you loosen the tensioner assembly you can slip the serp belt off the pulley or remove the tensioner assembly totally - your choice - but loosening the tensioner assembly about 3/4" away from the timing cover should give you enough clearance to slip the belt off.
Michael Star (09-23-2012)
Guy-Pierre Boucher
09-16-2015 05:55 PM
dragonfly777
Regional
09-08-2015 01:39 PM
