Supercharger pulley
Supercharger pulley
Can a Ford Lightning supercharger pulley be used on the Jaguar. I plan on purchasing a 2.76" non slip pulley from Billet Flow. So far I think it does but I want to be sure before the purchase. Your help would really be appreciated.
Link to pulley
http://www.billetflow.com/supercharger_pulleys.htm
Link to pulley
I would be almost 100% certain it will NOT interchange. I would call a supercharger expert and go over your plans. If I decide to port my super charger I will use Stiegemeier. I suggest calling and talking to someone. Here is the website. Lots of good information and a phone number!!
http://www.stiegemeier.com/home.html
I'm pretty sure the pulleys offered by companies such as Paramount, Eurotek, and Eurotoys are probably 2.93 sized. This is assuming the factory pulley is 3.0' in diameter.
A 2.76 pulley would net a MASSIVE gain...however, I don't know how the factory belt and tensioner would cope with the downsize. Were you planning on getting a new belt? POssibly from Gatorback?
More insight into this topic would definitely be appreciated...
If my math is correct and the factory blower pulley is 3" and the factory crank pulley is 6" then stock boost is in the range of 9-10 psi.
so this pulley:
http://cgi.ebay.com/ebaymotors/2003-...ht_3767wt_1165
This pulley is 2.8" which should equate to an increase of 1-1.5psi boost for 11-12psi.
from what i have read the cobra and lightning pulleys will fit our blowers seeing as they are all eaton M112 blowers. I was concerned about the offset but I think it is the same.
Good luck all, I will probably end up buying one of these pulleys and trying it eventually Seeing as how I have easy access to a pulley puller/installer anytime.
so this pulley:
they are both M112 blowers, if you put them both side by side they look different, the snout, casting, etc. The internals may be the same but the way it mounts and the pulley, unfortunately, are not the same. It would be nice to pick up a spare ford blower if it was the same to port since you can find them cheaper then a jag one
FS[MidWest]: 2001 Supercharged Vanden Plas
Col. Sandurz
09-28-2015 07:29 PM
