Suspension Problems
Suspension Problems
I just purchased a new to me 2000 S-type 4.0. I purchased it as driving to work car. I love the look and design of the car. One problem I am having is the front suspension kind of floats. When I hit a bump, sometime it pulls to the right and the steering wheel is all ways floating about. Other than this the car is in perfect condition.
Check the lower ball joints. They were known to have problems when they were new and there were a few TSBs and a recall to address the issues.
The Recall 136 was to check and tighten the joint nut. I had a few cars that the ball joint started seizing and loosening the nut until the steering 'wobbled'.
bob gauff
bob gauff
Fans don't sound to be running when they should.
a/c on -> fans run (mostly, but let's not get too clever)
a/c off -> fans run if the PCM thinks they should - in this case it trusts various sensors so something may be out
I vaguely recall someone had this before but can't recall the fix, sorry. Try some Searching
02jagstype
09-04-2015 08:20 PM
