Sway bar bushing size
Hello gentlemen, I have done a seach here and have not found out if anyone knows what size the sway bar is on the front bar of an 02 s type. I looked at crocodile62's posting about sway bars and he said that the front sway bar is 32mm on his 03 str. Is this also the size of the 02 front bar? I was looking into replacing the bushings b/c my car has a clunking sound when going over bumps and everyone says to change these first before trying the more expensive control arm bushings, when sounds brilliant to me. I want to buy the energy suspension universal bushings, has anyone used these with success or is oem the way to go? The universal bushings from ES come with brackets that i'm not sure will fit, any info on this matter would be greatly appreciated, thanks.
Received 2,192 Likes
THE NEW STYLE jAG BUSHINGS That have been out for years are the goods ones, they have a seperation cut in the side instead of the bottom like the bad ones. DO NOT lube them you will ruin them. Install dry, and to check if sway bar bushing, sway the car side to side with the steering wheel while driving slowly down the street. If if clunks while rocking side to side, its the bushings, throw some new end links on too while youre under there
ahunt4
09-19-2015 06:46 AM
philwarner
09-16-2015 10:40 PM
