sway bar bushings
![Exclamation](https://www.jaguarforums.com/forum/images/icons/icon4.gif)
how do i replace the sway bar bushings on a 2000 jaguar s type v6? i have alot of clunks and sounds from the rear suspension and some in the front. ive replaced the sway bar links all around,tie rods all around,new struts in the front but the back ones are still good for now,i know i have to replace the control bushings soon and the subframe ones too but i need to change the sway bar bushings first asap. Any help is always greatly appreciated, especially from Brutal. Thank you gentleman and have a good day.
same I posted looking for help in the rear end, these cars have lots of bushings in the rear. Hopefully you find help, knocking and clunking is much worse than my issue. Is your car on the road, has it been safetied?
Received 1,442 Likes
OK. Rule #1 . . . Go to Stickies or Gus' JagRepair.com or get a low cost DVD of full workshop manual for your model+year . . . read relevant section which shows the whole deal, then ask any questions that have you stumped. The R&R of front ARB is a simple process for DIY . . . but, having this bible by your side is really mandatory.
Best wishes,
![Icon Beerchug](https://www.jaguarforums.com/forum/images/smilies/icon_beerchug.gif)
Ken
Best wishes,
Ken
TCJAG88 (03-29-2018)
Front sway bar mount bushings require the heater tap to be removed FIRST.
The air box, aircleaner to some, lower section must be removed.
LH is a snap, and pushing the lower radiator hose CAREFULLY to one side is not the end of the world.
The RH will test your language, and ability to bleed. I have done both ours twice now, and the first time I refused to accept the heater tap section, and 6 hours later the bolt, YES, ONE DAMN BOLT, was out, but there is NO way of refitting it with the tap in the way.
Cross threading those 4 bolts is easy, o take care, been there.
I replaced both taps the first time, as the heaters were a tad iffy.
The Black car is coming up for them again, awesome roads we have here, and will be done sometime in 2018, with a new heater tap also.
Rear end,NO idea, it does what it does, and no noises so far.
beulahjag (04-03-2018),
cat_as_trophy (03-30-2018)
The following 2 users liked this post by NZxkr:
Grant Francis (04-01-2018)
XJ8JR
10-21-2015 12:04 PM
jimlombardi
11-03-2014 07:35 PM
04xtype04
05-04-2014 09:27 PM
