Swaying, please help! Jaguar Tech any thoughts
![Angry](https://www.jaguarforums.com/forum/images/icons/icon8.gif)
I have a Jaguar S-Type 2000 4.0. It has a slight sway left to right from 40 to 60mph. the sway increase above 60mph. I have replaced the FRONT upper and lower control arms on both side, I replaced the lower ball joints on both sides, as well the control rod, and the struts on both sides. I have also replaced the ball bearings (hub), and the sway link on both sides.
I have not got and alignment yet for it. Everything but the struts and sway link were done at a shop, and they did the alignments then. But the waying started happening when my struts went bad. I replaced the struts and that help the sway by bring it to a slight sway. Would alignment get rid of it completely or is this due to something else, like bushings or sway bar? If so how do you tell if they are bad?
Thank you,
Damian
Thank you,
Damian
Alignment is highly suggested after strut replacement on many vehicles, depending on the suspension design. You've come this far....
You didn't mention your tire conditions. With all of your suspension issues - do you have odd or uneven tire wear? Inner edges worn off? Proper inflation?
EDIT - dang it Rick you did it again. Is it the Cleveland passive-aggressiveness towards Pittsburgh?
Received 6,320 Likes
![Unhappy](https://www.jaguarforums.com/forum/images/icons/icon9.gif)
Hi sorry im new to the forum and apologize for sounding a bit ignorant.. I have a 01 s type with 120k miles, my car has been swayin from side to side i have done the wheel alignment twicce and im still having the same problem, my friend told me i most likely will have to change my rack n pinion? but just wanted to get you guys opinion.. again thanks
Please visit New Member Area - Intro a MUST - Jaguar Forums - Jaguar Enthusiasts Forum
for a quick intro so we can all say 'Hello'
philwarner
12-06-2021 07:13 AM
Doberman_Fan
22
12-24-2019 06:21 AM
Jaguar Forums Editor
Jaguar Press release
08-27-2015 03:18 AM
