Tech help Req.....New Intake throws P0171 & P0174 Error Codes with Freeze Frame Data
Here we go....
Right, definately no air leaks. Refitted standard intake and works fine.
Refitted new intake and deffo no air leaks, had it checked by my Indy.
We have narrowed it down after extensive testing to it only throwing the code when it is a warm engine restart.
I leave the car over night or a long period, it will start fine and run perfect. However if i stop for a coffee mid journey and restart her up after 5 mins throws the lean on both banks codes, reset the codes runs fine.
My Indy said it could possibly be an ageing MAF and the flow from the new intake is highlighting it.. ie too much cold air passing through too quick when it expects warm less dense air from a warm engine mid run..?
Any other thoughts..?
DTCFRZF P0171 & P0174
Fuel Sys 1 CL
Fuel Sys 2 CL
Load - PCT% 12.5
ETC (F) 19.9
Short FT1% 20.3
Long FT1% 19.5
Short FT2% 17.2
Long FT2% 19.5
FRP ( Psi ) 55.7
MAP ( in Hg ) 12.7
RPM (/Min ) 581
VSS ( MPH ) 1
IAT ( F ) 126
MAF (lb/Min) 0.681
TP% 5.5
Fuel Sys 1 CL
Fuel Sys 2 CL
Load - PCT% 12.5
ETC (F) 19.9
Short FT1% 20.3
Long FT1% 19.5
Short FT2% 17.2
Long FT2% 19.5
FRP ( Psi ) 55.7
MAP ( in Hg ) 12.7
RPM (/Min ) 581
VSS ( MPH ) 1
IAT ( F ) 126
MAF (lb/Min) 0.681
TP% 5.5
Check brake booster vaccume line running from brake booster to intake manifold. Check tube running from EGR to passenger side exhaust manifold. Check vaccume line running from throttle body to crank case ventilation (PCV) on passenger side cam cover. Check purge valve to vaccume line fitting (drivers side next to strut tower.
I have now swapped and refitted the modified intake/filter assembly back and forth several times to ensure correct fitments. I am only getting a lean code for Bank 1, and only after restart mid run.
Reset the codes and she will tick over/idle and drive fine until i stop and restart. At a loss at the minute as there is no obvious poor fitment or leaks.
I will book her in to my local indy and see if he can spend some time finding it. Hopefully the lean on both banks was a red herring and there is a vacum leak on one bank or a dodgy MAF.
Once rectified will report back, thanks for the input guys.
Idle seems fine, only does it after warm start up.....
Start up first thing and go for a run fine, leave it all day start and go for a run fine, reset codes and drive runs fine.... which is why i am questioning an air leak.
I am going to change the MAF sensor anyway to rule that out as they are not overly expensive, if still there then i will have to get her stripped down and check all pipes and gaskets.
He didn't say bank 2 has 0% ltft, or did I miss something? If that is the case, it could be the ECU, O2 sensors, exhuast leak (so more o2 molecules go to the o2 sensor) or as you say some clogged fuel injectors.
I just said if bank 2 would be for instance at 17%, it would not throw a code, only if you go over 18%.
Weird one... been okay on long and short journeys for the last 24hrs....!....The codes were either lean bank one or both banks, never bank 2 on it's own..!... so due to the sparodic nature i am changing out the MAF as a starting point and then working back. Should be here Monday so will get it in and report back.
As always thanks for your feedback and pointers....
Received 2,623 Likes
