Temperature problem
Be aware that there is more than one temperature sensor inside the S Type. I would start with the sensor behind the small grille above where the ignition key goes in. This is the interior temp sensor. Since the air flow is opposite for this one it builds up a layer of crud on the sensor because cabin air is sucked in thru the grille and over the sensor. Will be much worse if the car has been smoked in!!!!
The other 3 temperature sensors are identical but are mounted to the plenum system and only have clean filtered air blown over them as the air exits the dash vents. I changed one of the evaporator sensors and it did not help. The sensor above the key was replaced but I think it could have been cleaned. It had a visible layer of dirt on it. That fixed the problem. The sensors are only about $20 each in the US. Also this is the same part as the Lincoln LS. So you can order this at any Ford dealer. Sensor behind grille above key Ford Part # XW4Z-19C734-AA.
Evaporator sensor part # XW4Z-19C734-BA
See the pictures below. This is the evaporator sensor NOT the sensor above the ignition key. The little bulb part is what gets covered in dirt.
Thanks for all the info folks. I check these things and report back.
I can tell you without a doubt that 'XW4Z-19C734-AA' will not fit the S-Type. The ford part has only two connections because it only measures temperature. The Jag has four connections because it also measures humidity. Tried to repalce it last night - when I disconnected it and ran the A/C the only differance I noted was the fan speed was on low. Reconnected and fan speed back to normal. The other ford part went it without any trouble, but did'nt resolve issue.
Also might mention - even with the system on vent only, still get HOT air from drivers vents.
Thanks again guys,
Thanks again guys,
Great info SHOboat. I am another X-SHO owner too!! Drove one for almost 12 years!!
I did not know that the sensor also measures humidity?? Any chance you can post the correct part number or a picture?? This seems to be one of the more common problems with the S Type. The DCCV is the main culprit but other sensors and electrical things can be part of it too.
Air chaud avec climatisation temperature problem
Merci
#28
Received 2,263 Likes
Try a Jaguar dealer and make it clear that they'll get paid only when it's fixed. Please read my comments about Decarie Motors above. Try Scotti or Jaguar Laval.
Last month i report this problem to Jaguar Land Rover Laval i have an apointment and they work on my car two days after my apointment
(reply in this forum 05-30-2010 : Now i have hot air in the left vent on the driver side and cold air in center and the rith side, i went to the dealer last week and they said me , they have to take off the dashboard (10-12 hours labor) to find what is the problem ?? and i pay 300$ just for that.)
They dont no how to repair this problem , they change a relay of 8.95$ an said to close the vent of the driver side to dont have hot air !!!, now i have hot air on left side near the window and also on the right side near the window. In the center vent, left side is mid air and center right cold air !
May be i will try John Scotti in Montreal ?
#31
Now it's repair, the problem was the AC Control Module failure, this piece order to close the trap of the DCCV on both side left and right side, the problem is only one side receitp the command to close the right side.
My mecano cancel the dual climate control and now i have a standard climate , the passenger side could change the temperature but it's not in fuction, he fix the two electrical cables to one side only (the side who accept the command of the AC control Module), and everythig is Ok .
I have cold air in the four air dispaly in the car ,
WOW very good now.
WOW very good now.
