Tensioners replaced now P1388
Had the tensioners, all the chains and gears in my 2000 s 4.o v8. Got the car back, seems to run like there's a miss. After driving a few miles check engine lite came on p1388. Used the Jaguar cam lock down. Now they say I need 2 cam shaft sprockets. They were just fine before the repair. Any ideas?
P1388 VVT Over retarded – bank 2 possible causes.
Bank 2 VVT solenoid valve to PCM PWM drive circuit fault
Bank 2 VVT actuator oil supply fault
Bank 2 VVT actuator stuck
There are sealing rings (NNE2622BA) on the MODULE CARRIER for the oil supply to the V V Timing Unit.
They might be damaged or an oil change with a different viscosity might be the cause?
Could be that the VVT unit was not set correctly when the chains were installed/tightened? (set to full retard with special pin tool)
Could be, Could be, Could be, Could be, Could be?
Don't know, just guessing.
As motorcarman said above, just guessing at this point.
Have the shop that did the work go back over what was done to make sure everything is set correctly.
Here is a link to the Engine Course:
https://www.dropbox.com/scl/fi/nfvwk...=ngq9rub7&dl=0
Pay particular attention to the section on pages 24 through 27 of the course pertaining to the Timing Chain and VVT Unit.
