Test pipes
Got a couple quick videos. GoPro isn't very good sound-wise, but you should get the idea:
https://www.youtube.com/watch?v=WM4QobLEUcU
https://www.youtube.com/watch?v=4QULREnTYB0
Vid is up, and yea it is kinda loud. Looking at some 3" resonators to put on it soon.
Test Pipes - YouTube
If someone is going to do test pipes, here is how to keep your CEL from coming on.
(Sorry for the blurry pics)
First buy 2 spark plug anti-foulers (Part #42009)
![](https://www.jaguarforums.com/forum/attachments/s-type-s-type-r-supercharged-v8-x200-15/29581-test-pipes-708429_10151410117302853_595293680_o.jpg?dateline=1357522963)
The part that sucks is you have to drill on large enough for the o2 sensor to pass through. You need to use a 1/2" drill bit to make the hole. A drill press makes this job so much easier. You only need to drill 2
Before:
![](https://www.jaguarforums.com/forum/attachments/s-type-s-type-r-supercharged-v8-x200-15/29582-test-pipes-708762_10151409985227853_1947590335_o.jpg?dateline=1357522963)
After
![](https://www.jaguarforums.com/forum/attachments/s-type-s-type-r-supercharged-v8-x200-15/29583-test-pipes-728977_10151409973487853_1605869998_o.jpg?dateline=1357522963)
Screw them together
![](https://www.jaguarforums.com/forum/attachments/s-type-s-type-r-supercharged-v8-x200-15/29584-test-pipes-728732_10151409973967853_1899261020_o.jpg?dateline=1357522963)
Put the o2 into it
![](https://www.jaguarforums.com/forum/attachments/s-type-s-type-r-supercharged-v8-x200-15/29585-test-pipes-565919_10151409975557853_702302089_a.jpg?dateline=1357522963)
After that put it back into the car and hook it up. No CEL
Before:
After
Screw them together
Put the o2 into it
I used the low profile banjo style on my car as clearance is an issue.
O2 Spacer - Oxygen Sensor Spacer - CEL / MIL Fix - Oxygen O2 Sensor Adapter - O2 Sensor Extender
The following 2 users liked this post by JgaXkr:
Michael Star (01-07-2013),
Panthro (01-07-2013)
#30
#32
#33
#34
#36
Cats are there to burn any unburnt fuel+air. (That's the emissions stuff.) Cat efficiency codes mean it's not happening but also mean there was unburnt fuel+air or bad fuelling. What else are you saying such codes can mean / how else can they occur?
edit: I suppose they can also trigger (falsely) if you have an exhaust leak, but you'd want to fix that!
#37
The issue is that the computer is seeing the same values on both inline o2s which it interprets as a bad cat. There will always be unburnt fuel in the exhaust as a byproduct of combustion. And you are correct, the cat chemically converts the leftover, but by just moving the 2nd o2 our of the direct line of the exhaust stream, it won't throw the code. That to me means that combustion is sufficient enough to make it past the 2nd o2 without a cat in place and pass emissions.
This is the actual fault code
Catalyst System Efficiency Below Threshold
I hope this was a bit more clear
#38
aholbro1
08-05-2021 05:02 AM
xjrjag
09-27-2015 01:53 AM
