is there a headgasket sealer that actually works ie bars leak
The following 2 users liked this post by abonano:
fredn270 (08-16-2017),
Jumpin' Jag Flash (08-17-2017)
(Irontight) works and has been working since the 1930s originally designed for the common fault the model T ford cast steel blocks had cracking .
i have used it many times with only 1 engine that would not heal .
i always give the stuff a mention to customers who can not afford the work to be done or if the car is just not worth the expense and labor .
its not snake oil it works . and in one case i have a friend with a r32 GTR fire breathing 700HP BEAST , which has a ported alloy head that cracked in a port . and the stuff worked and several years later is still working . i stuck some in an isuzu bighorn years back that spewed its guts on the road and compression was bubbling out the radiator quite fast .it too was fixed for 60000km when it finally snapped its cam belt and went to heaven . many other life saving story's i have with this product .
point is not all miracle chemical products are bogus , some do work .
i will however point out that if you use chemi-weld as an alternative it will get you home but blocks every thing with a red concrete like substance . which leaves your block and heads un re condition able . this is also first hand experience .
The following 2 users liked this post by Datsports:
Received 2,263 Likes
When you have milky couloured oil it is now normally to late. The most accurate test that I know of is to use an emmision gas analyzer. You open the expansion bottle cap and put the nozzle that goes in the exchaust (making sure that it does not go into the coolant water). Then run the engine for a few minutes, if you get any hydrocarbons being found there that is more than what is the atmosphere. Then you have a blowing head gasket.
Actually, more a case of snake oil salesmen overhyping a product. They do work but have limitations and side effects. Beginning decades back in an era of not so high quality machining, General Motors "installed" this
Cooling System Seal Tabs | ACDelco
in quite a few brand new cars at the factory to prevent customers from bringing back their new car to demand warranty repair for just a few drips. It works to that extent. GM's use waned as quality increased in the late 90s.
If you decide to try it, don't use two much. Try one tablet and give it enough time for the little fibers to find their way to the hole and build their tiny little beaver dam. It probably won't happen overnight, maybe 50 miles. If its a bigger leak than a couple of tablets can fix, then putting in too much just risks clogging the system, you'll wonder why the heater isn't working all of a sudden or worse.
Padre (01-02-2018)
There's a big difference between a cooling system leak and a blown head gasket. The only cure for a failed head gasket is a replacement. Anything else is a temporary fix.
NBCat (01-04-2018)
hunterpedigo
06-21-2017 08:59 PM
hunterpedigo
10-29-2015 05:31 PM
