Is there a throttle cable adjustment for 05 S-Type 4.2
I was over in the XK section reading some posts as i am considering changing out my 05 S-Type for an XK and I read a thread where they were adjusting their throttle cables and noticed big gains in performance.
I began searching the forums for throttle adjustment for the S-Type and didnt really find anything so i am assuming that this is not possible but i thought i would hit you guys up just to make sure.
Thanks!!!
Thanks!!!
There really is no gain to be had and no point to a reset. The PCM recalibrates the TB, no need to second-guess it.
If what you want is to force the car to do maximum relearning - generally pointless or even a mistake unless you've fixed an engine fault - disconnect the battery. Then follow the Drive Cycle in the codes PDF.
I understand the later XK is essentially the same as our cars already are. (It got the same engine & autobox etc so what else would it be?)
If what you really want are power gains, do all the things everyone else always suggests - flow more air, and preferably cooler air - so pulley etc. The PCM will look after fuel, timing and so on. Let it.
payno (04-12-2013)
Richard_gib
09-12-2015 07:08 PM
hafren
09-07-2015 10:30 AM
