Thermostat?
Thermostat?
I was admonished to move this from an old and "wrong" forum, so here goes.
Good morning Brutal--My Jag is a 2006 S type with 4.2L and this code came on--my local mechanic (not dealership--none within a couple of hours drive) changed out the thermostat and housing and next day, same code again. I'm in Louisiana so same temps as Houston pretty much. Any ideas?
Thank you.
Thank you.
Received 2,263 Likes
Received 2,643 Likes
When DTC P0128 appears with the 4.2 litre-engined cars, it usually indicates the thermostat seal is leaking causing the thermostat to take additional time to open.
It is a good idea to replace the water outlet pipe, which contains a new thermostat and seal in situ, each time the coolant is replaced. The JLR part number for the water outlet assembly is AJ811793.
The water outlet is made from plastic and can only withstand a finite number of cold and hot cycles before failing. Quite often someone will replace the thermostat without replacing the water outlet housing assembly.
If the water outlet fails, it can cause catastrophic damage to the engine.
Ace Ford (10-18-2016)
Howdy NBCat,
DTC was erased after thermo/outlet/whole shooting match was changed and then code came on the next morning again after about 10-12 minutes of driving time. Reset a 2nd time after mechanic gave it a quick look, found nothing and assumed it was just a recurrence of the old code. Then came on again today, so 4+ stop/start cycles now.
I love a good mystery.
MrsToadsWildRide
09-07-2016 07:16 PM
thomash85715
08-27-2016 06:24 PM
