to those w/ Magnaflow hi-flow cats...
#61
I got the original part number from Summit, then simply shopped for the best price...
EDIT: actually, there were one or two vendors even cheaper than Wholesale Magnaflow, but they charged for shipping. If you live close enough to one to pick stuff up, each cat would be priced in the high $80s
#62
Phil, go for the Magnaflow "spun" cats found on Summitt Racing, prob the best price. I'll call Summitt tomorrow to ask them to draw up my order then forward to you. The freekin cats are absolutely the most clogged item on an STR's exahaust chain. Hi-flow cats will let her breath like there's no tomorrow.
![Icon Wink](https://www.jaguarforums.com/forum/images/smilies/icon_wink.gif)
#63
I've already ordered those; jag79 needs to know, though, that a part number is a part number, and all vendors that have Magnaflow parts will use the same part number. With this, he can order part #59926 (spun, metallic substrate, 2.5" inlet/outlet, etc.) from whoever is cheapest...in this case, Wholesale Magnaflow.
![Icon Hyper](https://www.jaguarforums.com/forum/images/smilies/icon_hyper.gif)
#64
Ahh...I should have mentioned this before. These cats are replacing my OEM cats, but are not necessarily OEM replacements (if that makes sense). I am ripping my entire exhaust system out and building custom.
I believe that the OEM cat is a single unit with 2 2.25" inlet/outlet pipes on each side (front/back). The spun metallic substrate cats we are all talking about have single 2.5" inlet/outlet pipes. Considering this, they look small because they are each (in effect) 1/2 of the OEM cat; what I mean is that you will need one for each pipe, whereas the single OEM cat had both pipes going into it.
I am not positive that the stock cat is 2.25". If the OEM cat does in fact have 2.25" inlet/outlet pipes, and you intend to keep the rest of your exhaust system stock, you might be better served by getting part # 59925 here http://www.wholesalemagnaflow.com/in...ducts_id=20737 for $96.29 ($104.66 at Summitt). You will need 2.
#65
#66
no, I meant that those 2 cats are enveloped in one heat shield, making it appear to be one piece.
However, after looking at some photos, it is obvious I was looking at the stock resonator and describing that. The stock cats locations are way too far apart to be covered by one heat shield.
#67
Phil, the Magnaflows are approx. the same length as stock. Stock has 2.25" inlet and outlets vs 2 1/2 for the Magnaflows. I'm elated to know you'll swap in a full exhaust mod. You won't by any means be disappointed. Wether you use dual resonators before the mufflers is a matter of sound preference. Just be sure you use a pre-muffler (acting as a resonator) that is flow through and has a 2 1/2" core (Walker Dynomax glass-packed tube mufflers). When nearing the end of the exhaust mod call Chris at Mina Galleries for a 1.5 pulley and Mike of EuroToys for a low temp. thermostat. Your STR will then be a "Cat Awokened". After these mods you'll be deciding on either a EuroToys ECU tune ($995 or a dyno-tune ($$$).
#68
![Icon Shrug](https://www.jaguarforums.com/forum/images/smilies/icon_shrug.gif)
#69
#70
Jag79 and Phil, with hi-flow cats you both will not by anyones imagination encounter a check engine light (CEL), etc. Who ever fear-mongered you into this thought pattern doesn't know what he's talking about. If you don't install both pre and post cat O2 sensors you will then encounter a CEL, period! Now get those Magnaflow "spun" hi-flow cats on...STAT! It's kind of getting lonely for me and Riski knowing we're the only STR guys with all this power and no one to share the glory with. My g-d...
#71
![Cool](https://www.jaguarforums.com/forum/images/icons/icon6.gif)
#72
#73
LOL! Awesome, both of you! Yes, both up and down stream O2 sensors are plug and play, i.e. Use stock O2 sensors and there's enough wire to move them around. Phil, after a full exhaust mod you and jag79 def. will have "tight jeans in the front". LOL! "Trow" in a K&N air filter, 1.5 pulley, and low temp. thermostat (No! you will not recieve a CEL with this either) and...ZOOM! I'm acheing for either an ECU or dyno-tune. Chris of Lomotion Performance (Poughkeepsie, NY) called me again yesterday. He invited me to his shop (you'll go nuts if you saw this place) to discuss tuning STR's. He travels the country tuning all sorts of metal. I'll keep yas updated. With a proper ECU or dyno-tune we come ever closer to the 500 hp mark.
#74
#75
#76
#77
Enthusiast, agreed, likely a different supercharger set up, etc. to attain 500 hp. This is why I wrote "...ever closer to the 500 hp mark" instead of "We will attain 500 hp with what we got". What we may have in the near future is a twin screw set up worth 100 hp on its own, requiring a full exhaust mod but not head work, etc.
#78
#79
Speaking of prices, how much you figure I would get charged for just swapping out my old cats for new ones?
#80
