throttle body (how quickly can i get a resonse, lol)
wow. dont know where to start, but long story short my 04 STR went into limp mode on the freeway yesterday. after SLOOOWLY pulling onto the shoulder, i searched for the problem. and its the throttle body (thanks to the previous threads!)
My mechanic (non jag) ran the codes and P0121 & P1111 came up. My question is if my shop replaces the throttle body does it have to be SYNC'd w/ the car? the shop said that once its replaced it will need to linked up via software which he cant do. I spoke w/ the dealership and they want $900 for the part + labor. Could i get some clarification what has to be done once the throttle body is replaced?
Don't rush to swap the TB, but if you do decide to I understand you must use an identical part but that it does NOT need programming into the car. Just plug in. You might get one from a wrecker or a reman. If there are gaskets (and I bet there are), plan to change them as you cannot have even the tiniest of leaks.
These throttle body connectors are notorious for allowing moisture to get in them, causing all sort of fun reactions by the ECM, including your codes, and limp home mode.
Your car isn't the first, nor will it be the last.
Take care,
George
I had mine rebuilt for less than $300 and that includes a lifetime warranty. You can ship it to them and get it back within a week. Mine has been flawless since I got it back and you don't have to worry about compatibility issues.
Here is a thread
https://www.jaguarforums.com/forum/s...+throttle+body
Current auction.
http://cgi.ebay.com/ebaymotors/97-98...Q5fAccessories
Here is a thread
Current auction.
I received my car back 2 weeks ago. It wasn't a jag mechanic, but he removed the throttle body checked it out, was dry, connections were good, etc. Well I when I picked up my car the check engine light was no longer on. The car has been running good until yesterday when it went into safe mode twice. Any other option than dropping hella cash at the dealer?
Did you not read my post?
![Icon Angel](https://www.jaguarforums.com/forum/images/smilies/icon_angel.gif)
pushing tin, im using the spot in your previous thread to get my throttle body repaired. So that place was tellin me that i didnt need to spend $400 (what i was quoted by a few spots) to have them take out the TB and its pretty easy and straight forward. the sent me the instructions on how the take it out....but i have no idea where its located. Ive never messed with anything under the hood (stereo only) and i have no idea how to take it out. if ANYONE could hook me up with a diagram or pics that would be GREATLY appreciated.
Sorry I can't help you, I had the mechanic remove it and send it off since it was there for two weeks having a bunch of other stuff done as well. I don't think he charged anywhere near $400 to R&R it though. I'm at work but I'll pull out the work order and take a look when I get home. I'm sure some of the others will chime in with advice too.
The P0121 error is most likely a TPS sensor issue, or connector/cabling one. You might just as well buy a secondhand unit on Ebay (even from another model, or even another car like an xtype 3.0 as I think that one has the same) and swap the TPS unit. Just check the number on the denso TPS unit and ask the seller if it is the same.
Here is just an example, but I am sure you can get them cheap anywhere:
http://cgi.ebay.de/Jaguar-X-type-2-5...item2a0e14dab9
p0121 = TP sensor range/performance. Tp sensor to ECM wiring : open circuit high resistance OR short circuit high voltage.
Diagnosis. Ignition in ON position. Press accelerator SLOWLY to floor counting to 5. SLOWLY let off counting to 5..repeat 3 times
turn car over.
code p1111...all DTC's cleared All engine management OBD monitor drive cycles are completed
