Throttle Body Issues
Greetings All,
I have a 2005 S-Type 3 litre. Within the past year I've been going into Limp Home mode with the ECU Fault, DCS Unavailable, Parking Brake Fault. Reading the codes it's a P2135.
I know this can many times be traced to a failing battery, so I replaced the battery with a new one. No Joy, as the problem began to become very common.
I ordered a remanufactured Throttle Body from a company that offers them with a lifetime warranty.
As soon as I finished the install, upon start the engine surged to 4000 RPM and then immediatly went into limp mode with the same symptoms and a P2135 code.
Question for the Wise Ones: Do I need to tweak the TPS on the throttle body to ensure that the idle RPM's are in the correct range? Is there anything else that needs to be done post Throttle Body swap out?
I did disconnect the battery and held the leads together to discharge the system, but it hasn't helped the problem.
Any help or insight at all would be greatly appreciated.
Best Regards,
Scott
Best Regards,
Scott
Sorry, I would have sworn I read you cleaned the tb and that you were wondering if you had not cleaned it well enough. I must have read it on another forum.
Edit
I got mixed up with this thread, https://www.jaguarforums.com/forum/s...-until-112046/
Edit
Hey Scott, here is something else that may or may not help out. I knew I read about this code P2135 awhile back and I jut got the chance to look it up.
Pay attention to Brutals posts in the thread (oh if he answers your questions, don't forget to push the "Thanks" button):
https://www.jaguarforums.com/forum/s...ghtmare-35470/
Here's what I did this afternoon.
Disconnected all throttle body connectors and cleaned them. The throttle body motor connector has some broken plastic on the wire side, so I pushed it firmly in place and secured with waterproof electrical tape. (This could be the culprit I realize)
I put everything back together and did a hard reset.
Upon turning the ignition to "On" but not starting the engine, it immediately goes into "Engine Systems Fault - DSC Not available - Parking Brake Fault".
I checked the battery with a Multimeter. 12.67 Volts with the vehicle off, 15.77 with the engine running.
@JAGV8 - The car was always dealer serviced with the previous owner and the dealer was nice enough to send me the service records. The procedure described in that tech bulletin was done.
Any ideas?
Scott
Any ideas?
Scott
from what i can remember its the throttle body and it usually throws that code when it gets wet (str mainly i think) or the connectors/wiring are faulty.
i know you replaced the battery but did you give it a good 24 hour charge before fitting it ?
i bought a new battery and had to have it replaced as it had a bad cell.
I was going to mention that you need to check the plugs I recently had a plug that one of the connectors was bent and contact was not achieved. Along with that you need to check all other connectors related to the harness and I think I recall a recent thread about a harness plug problem at the point where it comes into the car and I think it was on the right side.
