Throttle Position Sensor SOLVED!
The non-availability of a new replacement Denso 198500-3300 TPS has been the subject of much discussion on these forums. I am pleased to report that I found one on the internet for about$100. I cleaned the throttle body on my '04 V6 and installed it and it works perfectly! No reprogramming or Jag voodoo required! The only trick is to have the bit for the TPS screws. This is a common 5-point torx TS20 tamper-resistant bit, not a Jaguar specialty bit. Regular torx are 6-point and don't work. A set including the correct bit is available on Amazon for $8.99. I ordered the TPS from automotivepartsfactory.com. It was advertised for the X-type, but works perfectly on my S-Type (and, I expect, the XKs as well). I hope this helps you guys avoid having to buy a new throttle body from Jaguar. Carl
![](https://cimg9.ibsrv.net/gimg/www.jaguarforums.com-vbulletin/1920x1080/resized_20190111_171246_2683_380dd0c21514f3d17c232ad8c3077a39ac070280.jpeg)
![](https://cimg1.ibsrv.net/gimg/www.jaguarforums.com-vbulletin/1920x1080/resized_20190111_171354_8643_f103370ad42117a98d10b23f9ceb3902b636c433.jpeg)
![](https://cimg6.ibsrv.net/gimg/www.jaguarforums.com-vbulletin/1920x1080/resized_20190111_171300_7576_8fb39d400dfb644757e7629ece3b86257503d65e.jpeg)
![](https://cimg0.ibsrv.net/gimg/www.jaguarforums.com-vbulletin/1920x1080/resized_20190111_171258_9962_3b1540cddbc396c84122f9b67ddcf5c4414f0e5c.jpeg)
![](https://cimg1.ibsrv.net/gimg/www.jaguarforums.com-vbulletin/1920x1080/resized_20190111_171252_8808_16281f3ddfd90ab7d31df7d9555fa5a8b1414d43.jpeg)
A seies if photos from my dash coukd this also be to do with the thrittle body issue.
Also the speedo drops out and the rev counter too.
Happens every couple of months and clears after puging in diagnostics and clearing numerous fault alarm that are unrelated
I would start by charging the battery fully. These faults occur with low battery voltage. Car needs over 14 volts when running around 12.7 when not. might not solve the problem but worth a try.
How old is battery? Does car get daily use? short drives can kill battery.
I use the car an a daily basis. Not sure how old battery is.
Reards
Gary
i had my battery checked and it was only dishing out about 12.5 so i got a replacement and all has been ok up till now. 6 weeks.
if anything changes i will let you know
#28
This was for Jon89's old 2005 S Type 3.0, which my friend Todd now owns.
I couldn't find a new one. I did purchase a used one from ebay a couple months back for about $50.00. It came with a 30 day guarantee. No problems with it. Used throttle bodies were going for around $125.00 on ebay.
kr98664 (09-11-2019)
#30
#31
#32
nheald (09-24-2019)
#33
$50 and it did NOT work. I swapped it w/bad china one, the china one worked perfect, put the oem used one back in got ALL faults as soon as I turned the key to on without even starting it, seller said they we're tested,lol NOT> I just bought another china one, need to be on the road, if it lasts 7-9 Monthas again I am good, plus it is so easy to swap.
#34
I just replaced a 2002 throttle assy today but I did not look at the tamper-proof Torx Plus screws.
I am not walking down to my shop tonight but I will check in the morning!!
My guess will be T25 but why not buy a set?
https://www.amazon.com/Ram-Pro-Point...GVAY8XKK0DDH1Z
#35
#36
#37
Another update. Got a Jag USED tps off a 56k mile XJR and it didnt work, sent it back. Got another china one, put it in as soon as I hit the key got all the errors again just like Jag one, then put on the first china one that was periodically acting up back in and presto again it works! WTF? Ready to buy a for sale sign.
#38
Aus V8S
11-13-2015 11:01 AM
Guy-Pierre Boucher
09-16-2015 05:55 PM
OkieTim
09-08-2015 04:48 PM
