tie rod ends & sway bar end links
2003 S Type 4.2L
Can anyone advise a vendor to source from tie rod ends and rear sway bar end links for this car?
We tried searching Advance and nothing comes up in their search engine.
Also, would it be OK to assume that the standard tools I use to change these pieces on another vehicle would suffice? Or, better put, is there any unique tools I may need to swap them out?
Received 2,632 Likes
There are several good Internet vendors such as AutohausAZ, Motorcars LTD, Nalley Jaguar and others. There are no special tools that are needed to replace the anti-roll bar (sway bar) end links or isolators (bushings).
Have you inspected the front upper and lower ball joints and tie-rod end links as they are weak points on these vehicles?
NBCat
NBCat
