Timing chain alignment
I don't know if I need to align the bottom sprocket. I was told that you need to align both cams on top and the bottom one too. I noticed when trying to figure out how to get down there that the chain slips on the bottom socket. Not really slip but the chain moves around it and you can only move the chain cwhen you feed the other side of the chain. I haven't seen the bottom sprocket move when moving the chain.
do I need to align the bottom one? Or just the two cams on top?
Received 2,266 Likes
nothing got out of alignment At least I don't think so, besides the two cams that I took off.
I'm just wondering If I need to align the bottom sprocket when putting it back together. I'm doing this myself I don't know if you guys ever done it yourself but that's why I'm here. This time I brought pictures for more clarity
yeah the engine overheated a few weeks back. No new tensioners were installed. It gave me a check engine light but it went away I'm thinking it was just the overheat that caused the light to turn on. All the codes were giberish just one of them pulled up as ahead gasket at autozone . I'm not sure if they scammed me I ended buying two. Check engine light is gone too.
Received 2,676 Likes
If I might be so bold as to ask if you have referred to the Workshop Manual regarding the replacement of the primary and secondary timing chains and associated parts?
Did you perform a compression check prior to disassembling the engine?
To correctly set the camshaft timing, the crankshaft must be held in place by the holding tool AFTER the front pulley has been removed. Under no circumstances is the crankshaft front pulley bolt to be loosened using the crankshaft holding tool to hold the crankshaft against rotation. Damage to the engine drive plate will result.
Remove the timing cover and replace the primary timing chains, guides and tensioners as well.
During reassembly, use the camshaft holding tool(s) to correctly set the camshafts relative to the crankshaft before installing the primary and secondary timing chains.
The chain is still on the bottom crankshaft.
maybe were on the wrong page but look at the pictures it's just two cams off the car.
I never took out the front cover of the engine just the top valve covers. I didn't do any repairs it was a waste of time.
now I'm just trying to put it back together and the two cams back in place.
my question is, if I need to align the bottom cam if I never touched it in the first place? The chain still feeds downward without the cams and it doesn't move the bottom sprocket so that's why I'm curious about the alignment to the bottom sprocket.
I'm new to this. I didn't do a compression test before dismantling the engine. I should've though because that would tell me if the head gaskets is the problem. I also underestimated how big a head gasket job is. The check engine light went away though so I'm assuming it's all good.
when I put the car back together I'm going to run a compression test. I'm just wondering If I can align the two top cams and put the chain back on without aligning the bottom sprocket because I never touched it. Nor turned the cams to mis-align it.
NBCat (04-08-2017)
To confirm this is the V6 engine correct? Very few complaints regarding tensioners (usually reserved for the V8 4.0) but after looking at the pics I would swap all out...
