Timing off?
#41
Han
Thank you ! I will try this first thing when I get home! Can't wait to have her back, if I only knew it would be this easy to fix her I would have done it same month when it all happened.
^^^^ your trans shifter cable is streached and too loose to engage drive properly. Fix it now before you smoke the trans because it bleeds off line pressure when not fully engaged. You pull the center console and adjust with by loosening the 2 big nuts where the cable bolts to the shifter. You want even play on both sides of neutral so that neutral notch falls in the middle of the play.....follow?
#43
Brutal (03-22-2012)
#44
Received 2,191 Likes
![Icon Smallest](https://www.jaguarforums.com/forum/images/smilies/icon_smallest.gif)
#47
Torrid
16
08-05-2014 03:50 PM
prey
09-15-2011 01:53 PM
atom
07-19-2011 05:43 PM
