Which tint??
Also, I wouldn't do the tint yourself unless you are extremely capable.
technically no tint is the only legal thing in PA. However when you have gone to court and won as many times as i have, its a non-issue for me. With 20% all the way around, i haven't been bothered with at all.
it depends on how well you know the law. It passes inspection at a certified state inspection facility.......and there is no technical law for failing it during the inspection process....so if it passes the state certified inspection procedure, then you cant be dinged for it. Case closed. And i have beaten it about 6 times using this simple formula. And then i continue to reference the cases each time. And i have 20 on this car, i used to run limo all the way around. As an fyi.
SoCalJagS
09-27-2015 09:20 AM
Andrew Fanshawe
09-14-2015 07:40 PM
