Tips on Mods.
Old 12-07-2010, 10:23 AM
jeffzm's Avatar
Default Tips on Mods.
Here I go step 2 on mods to my newly purchased 06-STR. First step was a little one = K&N and flap removal (all good). Plan now is repair curb rash (previous owner) along with a matte black powder coating on wheels. Car will be in my garage for about 5 days on jack stands, what else should I do ? I am thinking paint calipers silver but would like to details the R in green/red also might as well tos some H&R springs to give it a better stance.(tire rack has them for $299.00).
So I am fairly handy for do it yourself stuff, just dont a full on machine shop. I will seach on how to for calipers and springs but any tips would be great and am I over my head for spring install myself. I also have a Jeep Rubicon and swapped springs but on a 4x4 much easier access.
My goal is to give the car a little more attitude and personalize it some.
Thanks in advance, really enjoying site and car.
Jeff
Old 12-07-2010, 10:38 AM
bfsgross's Avatar
Jeff, your on the correct path with the H&R Sport Springs. If you're handy enough to swap em on a Jeep ya sure can do em on an STR...then give her a 4-wheel alignment ASAP. I posted to your previous thread on other very effective mods so ya can refer to your previous thread. Good luck.
Old 12-07-2010, 11:07 AM
Michael Star's Avatar
H&R springs should be the first thing any STR owner does. I did mine a few weeks ago and it transforms both the looks and the handling of the car. Make sure you use the spring compressors that hook onto the outside of the springs as they are the only ones that are small enough to fit in the area that you have to work.
Old 12-07-2010, 11:37 AM
Pushing_Tin's Avatar
You could put some cross-drilled or slotted rotors on too.
Old 12-07-2010, 12:58 PM
jeffzm's Avatar
Bummer, H & R back ordered 6-8 weeks thru tire rack and also same directly to h & R.
Old 12-09-2010, 10:45 AM
jeffzm's Avatar
Any other go to's for H & R springs in stock ?
Old 12-09-2010, 11:16 AM
I know pelican parts had them for a while.
Old 12-09-2010, 03:56 PM
Riski's Avatar
I will try to find where I bought mine from....was a older jaguar restoration place....paid less that 200 bucks shipped for them new
Old 12-09-2010, 09:48 PM
jeffzm's Avatar
Great, if I cant find them in the next few days I will order thru Tire rack 6-8 weeks I did call pelican and they will call back friday re: availability. Just wanted to get it handled while sittin in the garage for 5 days and wheels off.
I am diggin this car, just different then anything I have owned had a modded m-3 on me today but I didnt react to his teasing, I kinda got a kick out of it.
Riski, thanks for checking it out for me.
Jeff
Old 12-10-2010, 01:31 AM
08Z06's Avatar
Are you sure the factory active shocks can handle the lowering springs without screwing them up? Also the Mina Gallery stocks their own brand of lowering springs. They have got to be real similar to H&R.
www.brakeperformance.com can custom make you a set of "Dimpled & Slotted" rotors for both front and rear for $700. I got them on my car, they look GREAT!
Old 12-10-2010, 05:42 AM
bfsgross's Avatar
08Z06, the Mina Galleries springs leave her front high whilst the H&R's leave her level and work fine with the stock CAT struts.
Old 12-12-2010, 09:44 AM
jeffzm's Avatar
Removing wheels today so I can take in tomarrow to have repaired and powder coated. Any tips on safely storing car on 4 jack stands with no wheels for 5 days.
Thanks, Jeff
Old 12-12-2010, 09:46 AM
bfsgross's Avatar
Don't let the kids near car.
Old 12-12-2010, 10:30 AM
jeffzm's Avatar
thats why I moved it to the back garage and will be locked up. Bye the way I did find H&R springs from Pelican be here inb 2 weeks.
Thanks for all the info.
Jeff
Old 12-13-2010, 07:02 PM
jeffzm's Avatar
Ran into a snag yesterday when one lugnut stripped an dcould not be removed there is a stainless sleeve over the lugnut . So i rand the car over to a freind that owns a body shop this a.m. and with about 45 minutes and some cool tools that I dont have we got it off. I returned home to take wheels off and get them to the shop for r & r and powder coating. Then back to my office and try to catch up, nothing is ever easy.
Also noticed a pddle of oil under left reat strut while on stands, is the strut bad ? Has anyone had problems with the stock lugnuts ? seems like a poor design.
Jeff
Attached Thumbnails Tips on Mods.-109.jpg   Tips on Mods.-110.jpg   Tips on Mods.-111.jpg
Old 12-13-2010, 08:33 PM
vance580's Avatar
The stock lugnuts suck. It should be another thing you replace since you have them all off go with a one piece design. This was the very first thing I did to my STR after hearing all the horror stories of people breaking them and since I have already had 2 flats I really didnt want to be stuck with a flat and a busted lug. I went with the one piece Dormans from Rockauto. Plus the chrome looks better the the dull polished look I think.
Old 12-14-2010, 06:03 AM
Jon89's Avatar
Received 4,364 Likes on 2,854 Posts
There are many threads from the January/February 2010 timeframe containing several options for solid one-piece lug nuts when a number of us here on the forum replaced our crappy factory lug nuts. This is a no-brainer. Just do it. You'll be very glad that you did....
Old 12-14-2010, 07:10 AM
JOsworth's Avatar
Originally Posted by vance580
The stock lugnuts suck. I went with the one piece Dormans from Rockauto.
Yes.... Have the Dormans as well...
Old 12-14-2010, 07:18 AM
The Chris X's Avatar
RE the strut - that's a lot of oil, you'll need to replace that strut and the otherside while you are at it. Did you happen to let the axle hang unsupported during your jacking up operation? It's happened to me when the car goes up on a lift and the shocks/struts are sort of hyperexteneded that's when they leak.
now...tell me about that buggy!!
Old 12-14-2010, 08:06 AM
jeffzm's Avatar
for sure replacing lug nuts = no brainer. currently the struts are all unsupported up on jack stands, thats when the left rear lost fluid. I am going to intall H&R springs guess struts also.
Jeff
Quick Reply: Tips on Mods.
