Tire Replacement
My used '03 has 225x55x16 and I can replce them with 225x60x16 for about half the price of the "55's. I ran it through a size comparison program and the only difference it showed was speedometer raeding of 70 MPH when actual speed is 72.2 MPH. Any other draw backs? I have got to get rid of the noisey tires that came on it even though they still have a lot of rubber. Don R
Check that the load rating is equivalent. I have no idea if there are fitment issues. You can check overall measurements on www.tirerack.com.
Here's another idea for you. Check with a local place that does racing tires work. Specifically ask if they shave tires. It's done to street/competition tires so that they grip better and don't over heat with the stock taller tread. You only want them shaved to true them up again. It might work. I have had a set of noisey tires shaved slightly, re-balanced and that got rid of my noise and vibration issues. You can't do it with faulty or badly worn tires. But with wear it will eventually come back.
Bob S.
Bob S.
al_roethlisberger
09-11-2015 10:04 PM
KarimPA
09-03-2015 07:32 PM
