Tire size
2003 SType sports package with 17" wheels
currently I have 225/50r17. I believe before that I had 235s, not sure why but I think that's what I had.
My question is when I'm looking at tires do I have to gets ones that have the "r" in it? Also, what alternate sizes could I get for that rim? My wife drives this car to work and I would say rarely goes over 50mph and for sure doesn't need them for any kind of performance.
Received 2,632 Likes
You can go to one of the Internet tyre retailers and look at a guide to understand the grading criteria and how to read the information on the sidewall.
The 'R' part of the description means the tyre is of radial construction, so if it is listed as 225/50R17, the tread is 225mm wide; the aspect ratio is 50% meaning the sidewall is 50% of the tread width; radial style construction and the size rim it fits is 17-inches in diameter.
I do not believe you want non-radial, or crossply tyres for a vehicle your wife drives, if in fact they are even still produced...
>a guy near me is selling his tires
What brand and model are they? That should tell you all you need to know.
Then go to http://www.tirerack.com and search for tires for you car. If the tires are compatible with your car they should show up there as one of the recommended choices.
Jaguar: Grace, Pace, and Space - Sir William Lyons
Received 2,263 Likes
Deviating from OEM sizes can have some pitfalls, the most common being a different diameter than stock. This will throw the speedometer and odometer off and can cause rubbing on the fender if a larger diameter is chosen. Rubbing might occur if a wider tire is chosen.
No, my apologies… English is not the first language for manyhere it appears, especially those from the USA – with reference to spelling that is!!! (sarc) Oh very bad Doug!!!
![Icon Twisted](https://www.jaguarforums.com/forum/images/smilies/icon_twisted.gif)
Gerard Radimaker
09-13-2015 10:33 AM
