Tire size, Appropriate??
Tire size, Appropriate?? Advice please
I have a S-type 4.0 (sport pkg), and my rear tires need changing. The standard tire size for the car is 235/50/17. If I change my Rear Tires to 255/50/17, will that give me a staggered look if I do that?? Thanks
Received 2,670 Likes
Amadauss (02-15-2012)
Well, It would be staggered, not just look like it.
The "staggered look" is normally achieved with different offset wheels. A true staggered setup is done with different width wheels and tires in the rear.
I'm afraid that running that width in the rear will only go a little towards the staggered look I think you want.
I also don't know if that size will fit on a standard wheel without hitting and or rubbing. It is also a decent amount off. The correct size to run to maintain overall diameter is 255/45/17. They will be wider but still maintain the stock diameter and height.
Here is a tire calculator that will show you the impact of different sizes.
Tire size calculator
While larger than recommended wheel and tyre combinations may seem desirable, or give the vehicle a more 'aggressive' look, installing wider wheels and tyres or changing the offset may increase wear on other suspension and braking system components due to alignment angle changes, increased unsprung weight or bearing load.
Most reputable tyre shops will provide installation recommendations that will allow different wheels to be used whilst maintaining correct body clearance, suspension geometry and of course, safety.
NBCat
NBCat
Gerard Radimaker
09-13-2015 10:33 AM
