Tires, 2005 S-type, inside tread wear
Guest
Posts: n/a
Does anyone have the exact specifications provided in the Technical Service Bulletin 20412, NHTSA Item Number 10021067, August 1, 2006? I would like to have the modified toe specification. My front tires are showing signs of cupping on the innermost tread; my assumption is that the toe adjustment may be the solution.
Received 9,010 Likes
RE: Tires, 2005 S-type, inside tread wear
Hey Robert..........dont know where you're based but take it to Kwik fit or some other tyre delaer if you're stateside and ask them to check alignement for you. Depending on where you go you'll find either it'll be no charge ( I've never paid for aligement) or a relatively small charge, job done.
Once you drive away and check ( I'm guessin the car is pulling ever so slightly to one side?) to see if alls fine, If not take it back and they'll readjust for you no charge.
Aas for the exact specifications. sorry I can't help. Were you thinkin of doing it yourself?
Jim
KarimPA
09-12-2015 08:15 AM
WTB[NorthEast]: X-Type Sport Wheels
Whitnessmouse
09-04-2015 11:09 AM
