Top Speed STR?
Old 04-13-2011, 10:41 AM
Michael Star's Avatar
Default Top Speed STR?
So I registered for the Texas Mile that is coming up in May. Anyone care to take a guess what I will top out at? I only have a Mafioso intake, and K&N.
Old 04-13-2011, 11:37 AM
carelm's Avatar
To the best of my knowledge, STRs are electronically limited to 155 mph. There might be some aftermarket ECU upgrades available that bypass the electronic limiter, but I'm not personally aware of them.
Mike
Old 04-13-2011, 11:48 AM
Well one thing I am going to try is a trick that someone told me. If you put it in 5th on the manual side, it will go past the limiter. Worth a shot!
Old 04-13-2011, 02:44 PM
The Chris X's Avatar
Would top speed be in 5th anyway? 6th seems kinda tall....
Let us know how it works out for sure!!
Old 04-13-2011, 04:48 PM
bfsgross's Avatar
I also read that 5th is not limited to 155. Mike, my educated guess is she will top out at near 170 in 5th, but this may take slightly longer than a mile.
Old 04-13-2011, 05:06 PM
qikcat's Avatar
I will be there as well to hang out with some friends and possibly drive a car if its finished in time. Be cool to seeing what that R will do. From what I have read about the gearing I think fifth is your best bet either way with stock HP.
Old 04-13-2011, 05:35 PM
That is what I am thinking too. I am tempted to pick up a 3lb pulley before I go, but I don't know what the car will do in the heat.
Sweet! If you see me say hi!
Old 04-13-2011, 05:45 PM
bfsgross's Avatar
Mike, ya can pop on a 3 lb pulley. Let the car cool down and place two bags of ice on charge coolers, and spray cold water through lower bumber-grill aimed at intercooler. This will give you a very cool-dense air charge for a strong start on your mile. Ya may not transfer the heat as quickly if performing this duty prior to setting out on the mile. A freer flowing exhaust also will build up less heat too. Don't wear engine cover.
Old 04-13-2011, 06:18 PM
Ya the engine cover never even came with the car I was running without the mufflers, and I might do that again
Old 04-13-2011, 08:15 PM
bfsgross's Avatar
Default Off with the mufflers
Yea, take off the mufflers...more flow and lower temps.
Old 04-14-2011, 09:09 PM
phaelax's Avatar
I sorta guessed an STR would hit around 170-175 also.
You'll have to let us know about the 5th gear trick.
Old 04-15-2011, 04:51 PM
qwiketz's Avatar
My guess is in the texas mile you'll be between 145 and 150.
Old 04-16-2011, 04:58 PM
Well looking over a lot of data from the last event, I think I will be able to hit 160-165 based upon looking at some other cars. There are quite a few GT500s that are running 175+, and an E39 M5 doing 155. I think if I get the pulley and exhaust done before I go 160+ is an attainable number.
Old 04-17-2011, 07:42 PM
bfsgross's Avatar
Mike, I hit 125+ in "no time" soon after stabbing the pedal at 75 mph...with a lot more power in reserve to pull her through the entire speedometer range. Put that 3 lb. pulley, "Mafioso" air intake elbow, low temp. thermostat, and manifold back exhaust mod on, and you'll swear she'll do 170+ mph. Not kidding.
Old 04-19-2011, 12:24 PM
chrislynn5's Avatar
How solid does she run after 120+? Shake at all? Drive well?
Thanx.
Old 04-19-2011, 12:57 PM
Staatsof's Avatar
Hey guys, before you do an event like this make certain of your tires OK?
Good brakes are handy too! LOL
If you don't know the entire history of the tires meaning you bought them and there have been zero repairs then toss them out and get new ones. I know this isn't a very long run but it's just not worth the risk.
I'll tell you a little story about the first time I ran the Nevada Silver State race. The night before the race my wife and I had dinner with another couple who like us were running the race the next day. He had just bought a Testarossa with 4K miles on it. The next morning they went off the course with a blow-out at 190mph. Five hours later (after the air abulance and coroner were done) when we went by that car was the size of a card table. He was thrown through the windshield and survived his wife did not and was burned to death in the car. He didn't know the tires from day one and perhaps a repair or some other mishap is why he had a blowout. No one will ever know for certain. I'll never forget it and consequently I don't f*ck around with safety.
If the car is indeed limited to 155 I doubt that you can get by it. It would be a huge leagl issue for Jaguar. It also means that the tires probably aren't rated for higher speed with that vehicle. Tire load ratings change dramatically when your speed increases at those levels. Check with the tire manufacturer and Jaguar first. This car should be capable of a lot more than 155 unless it's a GD brick at speed? My 4,000lb 300hp Q45 reached 161 in Nevada at almost 5000 ft of elevation so I think that the Jag is capable of a lot more.
The short run nature of this event really helps with this issue but heat can also be a factor so hopefully it won't get too damn hot this early in the year.
Have fun, take pictures and video to show us how you did.
The following 2 users liked this post by Staatsof:
bfsgross (04-19-2011), ChrisSTR (04-19-2011)
Old 04-19-2011, 02:03 PM
qwiketz's Avatar
whoops, I was going off our local event which is at elevation. In texas you should be at least 5mph faster than my estimates.
Old 04-19-2011, 03:44 PM
bfsgross's Avatar
chrislynn5, my rear struts have almost 100k on them, causing the rear to wiggle and shakes at high speeds. The stock CAT struts (front were placed on 4 months ago) are coming off to be replaced with aftermarket high performance struts. I'm checking with BRUTAL before this swap is performed. He mentioned disconnecting the CAT module won't set off a CEL.
Old 04-19-2011, 06:13 PM
Just put on a fresh set of Conti DWs around 1k miles ago. Also plan on changing the brake fluid and pads, and checking the amount of rotor I have left.
Quick Reply: Top Speed STR?
