Totally locked out of car; Key fob is dead
Just went out to go to work and found the electronic key fob is dead.
I saw a U-tube video on how to change the battery.... wife is going to store now as I type to get battery replacement.
So, how do I reprogram key fob? I have no access to inside of car.
2005 S-type w/ V6
2005 S-type w/ V6
Correction...
I opened the trunk and found that my battery is completely dead. It gave me no warning such as slow (ignition turning) car start.
I heard that replacing the battery, after battery is installed, that there is a few things that need to be done like stepping on the brake pedal a few times.
Can someone remind me of this process?
2005 Jag s-type v6
2005 Jag s-type v6
Received 6,320 Likes
Main car battery dead instead of FOB
I heard that replacing the car's battery, after car battery is installed, that there is a few things that need to be done like stepping on the brake pedal a few times.
2005 Jag s-type v6
2005 Jag s-type v6
One final question please....
I just replaced the battery with a brand new diehard and all seems to be well. Thanks to everyone here.
My question is.... on a 2005 s-type v6, if the alternator is under performing or not performing at all, will I get some type of warning light indicator?
If not, when car is running, can I disconnect battery to test alternator? I know you can do it in older cars.
NEVER disconnect the battery with the engine on...you run the risk of frying countless electronics. Check the voltage with a multimeter and the engine running with the battery in place....about 14 volts tells you the charging system is working.
msdg137
09-16-2015 06:24 AM
Ziggybeben
08-30-2015 02:09 PM
Andrew McVey
16
08-27-2015 07:21 PM
Terrance Williams
08-26-2015 11:50 AM
