Towing Points
Old 01-23-2018, 05:28 PM
Rex's Avatar
Rex
Rex is online now
Default Towing Points
The rubber plug in the rear towing point is being stubborn to remove. Should have done this often as regular maintenance but failed. Now stuck. Is it threaded or just rammed in? If threaded, turning threatens to break the plastic retainer attached?
Old 01-23-2018, 06:04 PM
JBzXJ40's Avatar
Are you not able to use the front one?
Im trying to remember now..... I think it just pulls out, not threaded. Is there not a hole at the rear to spray and WD-40 or equivalent?
Old 01-23-2018, 06:25 PM
Rex's Avatar
Rex
Rex is online now
Front one does not have rubber plug, rear one I cannot remove. Do not need it now but should be ready for deployment.
Old 01-24-2018, 12:52 PM
clubairth1's Avatar
Received 2,476 Likes on 1,944 Posts
You sure it's not left hand thread?
Old 01-24-2018, 01:47 PM
Received 6,360 Likes on 5,534 Posts
Old 01-24-2018, 11:41 PM
Rex's Avatar
Rex
Rex is online now
Brilliant! My manual only states "remove the plug", no mention of left hand thread.
Old 01-26-2018, 05:02 PM
Rex's Avatar
Rex
Rex is online now
Removed the plug. Must break the plastic retainer to turn. Had never been removed and was seized. Broke and drilled it out. Need a tap and die set or thread cleaner to finish. Bottom line is remove every couple of years and grease! Forward end is open and entire unit full of grit. Now need to buy new plugs.
Tally Ho
02-21-2016 07:51 AM
x
08-12-2009 08:00 PM
02-26-2007 09:24 PM
aquill1
01-21-2007 12:48 PM
Quick Reply: Towing Points
