TPS problem/need help...
Guest
Posts: n/a
![Icon Doh](https://www.jaguarforums.com/forum/images/smilies/icon_doh.gif)
Welcome to jaguasforums.com. I know that you are anxious to get started but we have a 10 post minimum. Once that is satisfied you will be given you opportunity to post photos and see other links. Please be patient and enjoy the site. You need to go to our New Member Area – An intro is a MUST.
As for your problem what are the codes?
Read the net about ETC (electronic throttle control) and similar names for these very high-tech, high-precision, high-cost items. And this forum, where Search will help.
You would need skills you don't sound to have (and most people don't have) to disassemble and fix the TB (throttle body).
If this happened once, clear the code and hope it doesn't come back.
Cleaning is not recommended but you may wish to attempt it if the problem keeps happening and if you've read up on the possible causes and have made sure they're not happening.
You might try an exact, used, replacement.
jimforrest (uk)
02-28-2019 06:42 PM
