traction/dynamic stability control light flashing
This is not a new issue for me. I have owned this 2000 S Type for five years now and this light has been flashing steadily. I have learned to ignore it but every now and then I think that I should do something about it. The car runs well and rides probably a little hard for a Jaguar but I am usually on freeways and well paved streets so it has not been a problem for me. I suspect it might run a little more smoothly if I were to get it fixed.
When I first bought the car I used to receive a warning on the speedometer strip about the DSC system malfunctioning but that has disappeared and now only the flashing wheel continues to tell me that all is not well.
I bought and used an icarsoft 1930 scanner in a few attempts to find the source of the blinking but the results were hard to read for a non-professional like myself. I THINK that there might be a problem with a rear accelerometer and I have been thinking of buying one and trying it out to see if that might be the source.
I would love to hear from anybody who has been experiencing similar problems, particularly if they found a solution.
Bob
Bob
previous scanner results
I wrote down the scanner actions/results the last time I used it. I will try to be as brief as possible. My notations are in italics.
MAIN MENU
Diagnose
OBDII Diagnose
DTC Library
Tool Setup
Help
I chose OBDII Diagnose. The next screen follows
MONITOR STATUS
Mil status off
DTCs in this ECU 0
Readiness completed 6
Readiness not completed 1
Readiness not supported 3
Data Stream supported 28
Ignition spark
Protocol Type PWN
Diagnostic Menu
P0153
O2 sensor circuit slow
Response Bank 2 sensor
I tried all three choices and got no reaction.so I hit the escape button and went back to "erase codes" in the previous menu and got the following choices:
Hints
Clear/reset emissional related diagnostic information. Are you sure?
Not being sure I hit "escape" which led to
I/M readiness
Since DTCs were cleared
The drive cycle not supported on this vehicle
I hit the second choice about DTCs being cleared and got
All responses ok
I then hit the third choice and got
N/A
I then went back to the main menu and chose "Diagnose" which precipitated the following:
MAIN MENU
Jaguar
S type
1999-2001
Manual Select
Adaptive Damping System
Read DTCs
No DTC
I then went back to the main menu and chose "Datastream" which led to the following screen
Right arrow
I hit that which led to
All datastream
Right arrow
I hit right arrow three times which led to
Right damper firm
B1676
Battery voltage out of range
U1262
SCP [J1850] communication bus fault
This is about where I gave up. These are old notes and I have probably missed bits and pieces of information or transcribed the information poorly but this is all the record I have. I can give it another go around and report back what I found but if you see any faulty steps in this story please let me know.
MAIN MENU
Diagnose
OBDII Diagnose
DTC Library
Tool Setup
Help
MONITOR STATUS
Mil status off
DTCs in this ECU 0
Ignition spark
Protocol Type PWN
Diagnostic Menu
- read codes
- erase codes
- I/M readiness
- data stream
- freeze frame
- O2 sensor test
- on-board monitoring
- evap system test
P0153
Hints
I/M readiness
All responses ok
N/A
MAIN MENU
Jaguar
S type
1999-2001
Manual Select
Read DTCs
No DTC
- All datastream of page
- Number of permanent diagnostic trouble codes
- Brakes signal [SCP]
- Damper firm-battery voltage out of range
Right arrow
All datastream
Right arrow
Right damper firm
B1676
U1262
I think the brakes signal scp is involed. Scp means serial protocol network. It is the wiring per say for communication. Go back into jaguar diagnosis mode and get to the modules again. Select abs and see if any codes are present. No need for the obd2 function as yet because the codes we want are jag specific. The battery voltage was probably a low voltage state at some point. That being said, make sure your battery is fully charged and can hold a charge
Flashing DSC light as well
I’m also trying to solve my persistent flashing DSC light in my ‘02 3.0 Sport.
I have no error codes an there is no ABS warning light.
I have an iCarsoft 930 that I’ve used to get into my ABS module live data stream. I’ve screen shot some of the relevant data points - if anyone can help make sense of them, I’d much appreciate it.
Does that DSC sensor supply voltage at 122.8V seem correct?
Steering wheel angle output seems to be a bit bonkers as well?
Can anyone tell me about Yaw rate and what that means in relation to speed sensors etc? See attached.
Ive cleaned my rear speed sensors and reluctor wheel. My front speed sensors have a different housing on the left and right. Is that normal? See pics.
When looking at all 4 wheel sensors on live data whilst the car is moving I notice that they don’t show an exact change of speed at the same time - the fronts are off by a split second. Would that be a problem?
Thanks for any input.
cheers,
Ben
Left front wheel speed sensor
Right front wheel speed sensor
cheers,
Ben
DSC light still flashing
Thanks for your really valuable input, Ben. I have never been able to solve the flashing DSC light on my 2000 four litre and have basically learned to just live with it and ignore its flashing. I think the car runs a little hard because of it but I don't know because I have never known what it is like to run the car without a flashing DSC light. I considered replacing a sensor on spec but haven't got around to it. I am looking forward to the responses to your post.
I found the icarsoft information baffling--I am only a shadetree mechanic and barely living in the 21st century. I hope you get some good replies to your question.
Bob
Bob
That's an odd one. The value seems so far out of range, I'd suspect some sort of issue with the scanner interpreting the true value, versus an actual fault.
Could be. I recently replaced both front hubs on my '02. The new hubs (Timken brand) had a physically different sensor than the old ones (OEM?). They plugged into the vehicle harness just fine, but the sensors (and attached pigtails) were not interchangeable.
pauljag
11-20-2015 09:38 AM
jaguarlady03
05-17-2013 11:23 AM
