Trans fluid
The type of fluid and instructions to check and fill should be on the transmission pan, under your car. I'm not sure what kind of fluid a '03 S-Type 4.0, but it should be a Mercon fluid, just depends on what specs.
My '01 S-Type's 5R55N transmission takes Mercon V. Check on your transmission pan to make sure.
If it's a 4.0 - and be sure to check - it'll have the 5R55N trans, which uses cheap fluid.
It's critical you check what engine it has. You can even look up the car by VIN on FordEtis home page to see.
The following 3 users liked this post by JagV8:
Trans flud
HY.every one...DHORSLEY.. THANKS FOR your HELP. I DID WHAT YOU SAID.. CHECK THE TRANSMISSION PAN.I FOUND THIS #..ZF-GETREBE-GM11-0501-216-243B-PA66-GF35..AND IS 2003 JAG STYPE 4.2..WHICH TRANS FLUID USE.. IM NEW TO JAG.I HAVE THIS CAR FOR 2 WEEK. AND I LIKE.BUT I HAVE TO FIX SON STUFF.. THK .HAVE A GREAT DAY..FROM FLORIDA YOUR FRIEND. EDGARDO.
I thought '03 was the first year for the ZF 6 speed.
With that trans, the purists will tell you to get the ZF Lifegaurd 6 fluid.
I, however, chose Ford's Mercon SP fluid. I ran that for over 10k before I sold it.
It had the lurch before and after. Otherwise, drove the same.
You in the US, look for Ford Mercon SP,was made for the lincoln Navigator with the same transmission. You can get it for around $6 a quart at most auto parts stores, but will have to order it. Now Ford has supposedly changed that to a newer specification and I haven't read where it's compatible, so look for Mercon SP.
