trans linkage ?
i went and changed my oil today, after watching the oil change video (by vance580) in the faq section, i was going to check the shift linkage bolts but didnt see them, i have a 2000 stype with 3.0 are they in the same spot? does my car even have them? thanks in advance
-dan-
-dan-
-dan-
-dan-
![Icon Wink](https://www.jaguarforums.com/forum/images/smilies/icon_wink.gif)
Yours are most likely in a different location. You have a different transmission. I have never worked on the early model trans. The video is for the ZF26 trans which got switched into the Stypes in 2003. So you have the early Ford type trans not sure where the linkage is or if that is a common problem with that trans. It is common on the ZF's to come loose.
Bodyman, I posted a pic in #16 https://www.jaguarforums.com/forum/s...smission+bolts
Yeah... you can do that...but they are easy to tighten and apparently an absolute bitter-ex-wife to remove and replace!
Dan,
Sorry dude, you are SoL for pics. There may be one on here somewhere, but I don't recall it. As Vance said, you've got a different xmsn and it mayn't even be an issue on that one...no matter, you can still worry over the park-pawl or whatever it is that devils the pre-ZF xmsn models!
Dan,
Ugh, never heard that one before but completely understand. Don't ask how I know.
![Icon Shrug](https://www.jaguarforums.com/forum/images/smilies/icon_shrug.gif)
