Transmision limit: Horsepower and torque
So I was wondering before I begin installing and buying more upgrades for my STR, Whats the horespower limit these transmissions can handle. I wasnt going to go full TS Supercharger or anything major like that but you know the basics.
I have a Mina Exhaust right not, but plan on installig the 1.5 pulley, P&P supercharger, and then get it tuned. Is my transmission going to last after I upgrade to more Horsepower and torque? Anythoughts would be appreciated, thanks!
According to other folks here, the max input torque for the ZF 6HP26 is 600 newton metres (443 lbf-ft). HOWEVER, I have seen a two Racing Green XKRs with a methanol injection kit, one producing 475HP and 461 lbf-ft with the same ZF 6-speed, and other one rated at 450HP and 450lbf-ft with a "sequential gearbox."
You may have to check on the year of the vehicle as well as there were some minor improvements over the course of production.
Be careful with this! Yes the transmission is rated to 444 ft-lbs max but the exact rating of the model in the STR is unknown. Many different applications of the 6HP26/6HP28. Attached is the ZF transmission document and it says "model specific".
Does anybody know what it's rated at when installed in the STR?
The 6HP26 (used for the 4.2 engines, being it a STR/XKR/XJR) is rated to sustained 600nm use, so 600nm CONSTANT all the time (all rpms!). The short peak torque it can handle is of course higher than that.
The 6HP28 is rated for 700nm sustained use, where of course the peak torque is again higher than that.
Yes he has also mentioned the thought of selling his STR due to repair costs and inconvieniance and switching back to cheaper and more readily available mods for Amercan muscle..Don't know if he pulled the trigger yet
