transmission advise
Sometimes they develop a bad learn from a unique sequence of events.
you could drive it differently for a day or two to see if there is any difference.
As an example when I take my wifes 04 xj8 out for gas, the shifts can be slightly mushy.
After a few brisk hard accelerations it changes slightly to accomodate my style.
Not a huge difference but enough to be noticed.
In the OP case, he could start to see a difference. Mybe enough to give it more time and avoid getting it reset to default at the dealer. ($$)
Hi Achysklic, I am wondering if you ever got your hard shift 1-2 resolved? I have a 2004 XK8 with this exact same thing. It isn't the downshift lurch from 2-1, but upshift from a stop from first into 2nd. All other shifts are perfect. I had the fluid/pan/filer changed by the dealership to stop the bark sound from 3-4 (and BTW, the dealer said that didn't fix it, so they found a bottle of the anti-bark additive from another dealer, and that did fix it), but this didn't fix the hard shift 1-2. I tried pulling the negative battery cable and touching it to the positive (left like that for 2 hours) and then doing the "adaptive reprgramming" driving sequence discussed within the forum, and that had zero effect. I hope someone has a definitive resolution to this. I don't want to pay the dealer for their troubshooting, rather point then to a TSB or something. Also, no codes or anything.
