transmission fault no codes
Ok so its been a couple months since my last post. I have succesfully trailored my 2002 s-type 3.0 from philly to upstate ny. It was known to have a transmission fault so first thing I did was installed a new filter and refilled what was in the pan. Fluid smelled pretty burnt but no debris or metal shavings in old fluid or the magnet. It shifts fine under normal accell from 1-4 than has a minor jolt into 5th. Under wot it shifts hard from 1st to second then from second to third down shifts than upshifts but only under full throttle. I see others who found codes for their transmission faults however I have no check engine light... just the transmission fault in the display a couple seconds after starting the car. Do u need a special code reader to get the code?
I am pretty sure it does, just don't know the cost. I have a little lurching every once in a while. Planning to take my Jag to Austin,Tx this summer when I visit my sister, there is a Jag dealership there....I am going to get a computer diagnostic and check for updates. Ask some of those folks in the threads, several here are pretty knowledgable and can help..I only own my girl for 1.3 months.
Well do some more reading? You have the common Ford 5 speed and it does not have a TCM inside it like the 6 speed ZF does. Everything run by the PCM/ECM. But that transmission has it's own list of problems. The top one being the valve body/solenoid pack.
You should be able to get the codes. Have you tried to have Autozone do it? Be sure and clear the codes while they have the reader hooked up.
Did you check fluid level to ensure the case is full? Also, what type of fluid did you refill the case with?
philwarner
25
06-26-2021 05:43 AM
