Transmission oil leak.
There is a plug on the RH side of the transmission that needs to be removed with the car running. The fluid is checked when it is between 30-50* C, while the car is running on a level surface. This is not going to be easy for you without a lift, or having the car safely on jack stands.
Be safe.
Be safe.
Received 6,323 Likes
I see the OP was back in Nov., if you haven't read this https://www.jaguarforums.com/forum/s...ad.php?t=30991 then this is what you are looking for. I'll bet it isn't a pan bolt that is leaking but the rubber sleeve that has been mentioned.
aholbro1
08-05-2021 05:02 AM
