Transmission question
Hi,
Sorry if this has been asked before, I'm new here and searched before asking but didn't find anything that related to this particular issue (if it's is one issue).
Recently bought 03 S-Type and it's got a bit of a noticeable miss and throwing the engine code (P0301). So, ok, ODBII confirms the miss, cylinder 1. The issue I'm having is when the missfire is present, the transmission doesn't want to shift. It's almost like it goes into neutral. When it's not popping, it seems to work just fine. There's no transmission codes on the ODBII.
Could what's happening with the miss be causing issues shifting cause of a vacuum loss or something? Is there a way for me to diagnose this?
Thanks for your help,
Roadie
Roadie
Misfire issues on these cars are commonly caused by vacuum leaks, failing coils and occasionally, failing spark plugs. If your car has the 3.0 V6 engine, misfires are also frequently caused by the failing/leaking Intake Manifold Tuner Valve O-rings (usually referred to here on the forum as IMT O-rings). There are two of them, and the new version of them is green in color. If you have the 3.0 and the IMT O-rings have never been replaced (the old-style factory ones are colored yellow), I would start by doing that relatively easy and inexpensive job first. Search the forum using "IMT O-ring replacement" as your search phrase and you'll get the step-by-step instructions on how to do this....
If your car has the 4.0 or 4.2 V8 engine, it has no IMT O-rings so this fix will not apply....
A weak or failing battery can cause transmission problems (along with a myriad of other problems). Strong batteries in these cars are absolutely mandatory for fault-free operation....
Put your car details in your signature and you'll always get more help when you ask for it....
roadierfl (01-10-2017)
roadierfl (01-09-2018)
