Transmission Service
Guest
Posts: n/a
Our 2003 S-type has approximately 40,000 miles. I wanted to change fluid and filter in the transmission but was told that it is a sealed unit and the fluid cannot be changed. I have a very difficult time believing this. Has anyone else had their tarnsmission serviced. Engie is the 4.2L V8 and the transmission is the auotmatic.
Guest
Posts: n/a
I don't know about this transmission which is why I haven't repsonded before, but it is not out of the question. Modern Mercedes transes are sealed and unserviceable. The thing isn't dropping the pan and draining the unit; the problem is the lack of a fill hole. In the mercedes transes, there is no fill hole tapped into the trans case. I would suspect that the jag fill hole is not reachable without dropping the trans or it doesn't have one. Whatever you do, don't drain the trans without knowing how you are going to refill it.
Guest
Posts: n/a
Guest
Posts: n/a
Guest
Posts: n/a
Guest
Posts: n/a
ORIGINAL: Vegasdan
I just got my answer on the durability of this Jag's tranny. 39,000 miles on my 2000 3.0 and I need a new transmission. $6,000. Ain't that dandy. Started showing a warning light "Transmission fault". Now I know it's my "fault" for buying this thing.
Shouldnt it be covered under warranty?
Owners manul states that no service is required unless "sever duty" opertated....i don't know what that means, but as a mechanic, I highly recommend getting the fluid changed. The dealer can do it and will be happy to once you tell them that you will pay.....100 per hour plus 100 for fluid......
________
Volcano vaporizer
________
Volcano vaporizer
aholbro1
08-05-2021 05:02 AM
