Transmission shifts rough after dead battery
I would really appreciate some assistance--my 2003 s type, v6's battery died and now the trans shifts rough and irregular. Driving hasn't corrected anything. Going up hill it makes a groaning sound and shifts up and down. Will the computer system correct itself w/more driving? I am afraid to cause damage to the trans!! Or maybe fluid is low? Just replaced pan and fluid (synthetic). Heeelllpppp.
![Icon Errrr](https://www.jaguarforums.com/forum/images/smilies/icon_errrr.gif)
I would really appreciate some assistance--my 2003 s type, v6's battery died and now the trans shifts rough and irregular. Driving hasn't corrected anything. Going up hill it makes a groaning sound and shifts up and down. Will the computer system correct itself w/more driving? I am afraid to cause damage to the trans!! Or maybe fluid is low? Just replaced pan and fluid (synthetic). Heeelllpppp. ![Icon Errrr](https://www.jaguarforums.com/forum/images/smilies/icon_errrr.gif)
Hi there, first things first, what is the current state of your battery? When you said it died, what did you do then?
Platinumforme (02-15-2013)
If you have a properly working battery now (or change it to be one), the PCM will set about relearning engine tolerances (the learning was lost when battery died). If all goes well it will smooth out and then the trans should also be OK. However, it's possible this process won't go well, perhaps a latent fault pops up or something. Post again if that happens. as you'll need an OBD tool with live data (or visit to someone with one)
Perhaps tell us a bit more about the timing of the trans service and the battery dying and when things started acting up?? What happened when?
As you probably know it's not that simple to check the fluid level and many people have messed it up including Jaguar dealers.
I did mention I had to replace the trany pan. The auto techs where I work did the job for me--replaced w/synthetic fluid; 3.5 qts.
Battery might still be dead, I would examine it closer.
So you're saying the battery died WHILE it was in for transmission service, and once you got the car back, it's been shifting poorly?
What makes you think its the battery, and not related to the transmission service you just had done. Seems like it could be equally likely the transmission service may have caused this issue to come up.
The issue sounds like it could be related to fluid level, seeing you had the pan and fluid drain done. These transmissions are very particular about fluid level, and not many tech's know the proper procedure to fill it back up,
Platinumforme (02-16-2013)
Received 6,310 Likes
![Talking](https://www.jaguarforums.com/forum/images/icons/icon10.gif)
Yes, all good now... I should trust my gut feeling.... But thought I am just the layperson. I have another issue: I had a coolant hose leak which corroded my heater valve, then shorted out my temp. Control module. Things have been good, thanks to your forum and advice to fix the damaged circuit w/a solder pen; but when winter came around, heat does not come out of driver's side very warm at all. Also I have a mystery drain on my battery. At this point, I have shut the driver side vents, and am using the key to lock/unlock the cat, and not set alarm. Requesting your valuable thoughts on these two issues above. Thank you.
![Icon Imnotworthy](https://www.jaguarforums.com/forum/images/smilies/icon_imnotworthy.gif)
Hate to bring it up but you did NOT see the transmission leak yourself correct??
The reason is our ZF transmissions leak at an electrical connection sleeve. It is so common I would almost say that it will eventually happen to 100% of the cars. A pan leak is not common at all. Plus when the sleeve leaks it comes down and drips off the transmission pan so it looks like the pan is leaking. The sleeve is only $15 but can only be changed after the pan is removed.
So long story but I would really check the transmission sleeve. Also don't use the shop who changed your pan again. They don't know how to fill and check the level properly. Plus you should be using the proper ZF fluid which is NOT synthetic. With your description I still don't feel like they got the level correct but it must be closer to the proper level because the shifting improved.
Lord only knows what else they don't know!!
About your second set of questions. Start another thread, as it is too confusing trying to fix multiple things under the same thread title. Plus no one can find good information when searching if it's buried along with unrelated problems.
aholbro1
08-05-2021 05:02 AM
Rlover
03-30-2016 10:04 PM
