trunk / boot will only open with remote
johnleavitt (09-11-2016)
Motorcarman and JagV8....with my tail between my legs....you are both correct. Problem solved. This is my wife's car. The Glove Box is so stuffed with crap that a little cosmetics box slid over and activated valet mode. It did not quite lock the switch so when I ever I opened the glove box it looked like it was off. When I closed the box, it went into valet mode. I am so glad I didn't start a wire trace today......Thanks to both of you.
JagV8 (09-12-2016)
The pushbutton in the glove cubby is a manual switch so there is no electronic VALET MODE as such. It simply disables all boot release functions except the remote and key.
There are some harness connectors in the end panel next to the glovebox that might need a 'look-see'.
bob
bob
When I went to NP00 (New Product 2000 the S-Type intro) training in Mahwah NJ we had an instructor that pulled a wire to the switch in the glove cubby.
It took us a while to run through the electrical guide and figure out the switch fault.
It is something you don't forget when the fault comes up again.
bob
bob
bob
bob
Dionne Kae Dickey
09-09-2016 03:10 PM
